Previous in Forum: Transformers   Next in Forum: Capacitors for Starting Single-phase AC Motors
10 comments
How to Calculate Maximum Demand
08/07/2009 4:15 AM
how to calculate maximum demand for apartments
Re: maximum demand
08/07/2009 4:28 AM
What have the apartments got in them for loads?
What is the occupancy pattern?
What methods of microgeneration are present that will offset the grid demand?
What is the heating/cooling load as a result of the building's construction and latitude?
What do local building codes say on the topic?
What help can the architect's office's contacts give on the topic?
Re: maximum demand
08/07/2009 6:58 AM
Uhm... Do you mean how many people want apartments?
Re: How to Calculate Maximum Demand
08/07/2009 9:00 AM
maximum demand for what? water? electricity? cable television?
08/07/2009 9:57 AM
Your local electric code should provide guidlines for you to use.
08/08/2009 6:49 AM
hi
1-- what is the nature of buildings ---can get VA/m²
2---total connected load
3 demand factor applied to each
3 diversity factor 1.1---1.5
this will give total load KVA
Correct me if i am wrong i am learner
08/08/2009 1:09 PM
hi!
Maximum demand now a days is not only a technical problem , but social & political too. load shedding programmes imposed by Government reduces the virtiual demand on the system.
In today's era, with the dense population, demand goes on rising ! & all engineering assumptions of diversity factor / load factor / utilization factor goes wrong if you are not smart enough! to predict the local conditions , where you want to predict the demand!
However, if you want to calculate the maximum demand, following may help you out.
Maximum demand = connected KW * diversity factor * load factor
_______________________________________ KVA.
POWER Factor
for residentiAL AREAs , power factor = 0.65 ( low due to high inductive loads )
diversity factor = 0.45 to 0.8
( rural / urban / commercial areas )
rural - 0.45
urban - 0.6
commercial - 0.8 - night peak hrs.
CONNECTED KW - YOU MUST KNOW.
Exploring the Science of Electricity
11/22/2009 11:13 PM
Diversity factor is usually more than one.
Diversity factor is the ratio of the sum of the individual maximum demands of the various subdivisions of a system (or part of a system) to the maximum demand of the whole system (or part of the system) under consideration.
I am curious to know how Diversity factor comes less than. Would you pl. give some reference.
08/09/2009 3:37 AM
we normally use diversity on over all system load
and demand load on individual load to get the calculated load
what about load factor ---
10/28/2009 2:52 PM
oh my goodness! what maximum demand you need? please elaborate further...
11/22/2009 11:29 PM
Maximum Demand for the Apartments = (Sum of maximum demand of individual flat) / (Diversity factor)
Diversity factor may be considered as 1.2 - 1.5 depending on the user pattern. Like in daytime lights are off but AC/fan & other gadgets are on. While in the night Lights are on & you may prefer fan over AC & so on. Few flats may remain closed for the whole day & the flat members might return back in the evening. Few flat menbers might go out in the evening & come late night. All these factors you have to check while determining the diversity factor.
Register to Reply 10 comments
Anonymous Poster (3); harry potter (1); ikhanuk (2); KKK (2); PWSlack (1); wareagle (1)
You might be interested in: Power Quality Analyzers, Utility Meters, Water Heaters
