Previous in Forum: What are Steam Jet Air Ejectors?   Next in Forum: Balance Leak-Off in Boiler Feed Pump
India - Member - New Member
What is a Boiler Feed Pump?
08/09/2009 1:33 AM
what is boiler feed pump. its principal and working .
Re: power plant
08/09/2009 3:00 AM
In a boiler steam drum is the part with highest pressure. In order to pump the boiler feed water which is at low pressure , a pump is required which is called boiler feed pump. As principle is conerned, it is a centrifugal pump.
RK
Re: power plant
08/09/2009 5:09 AM
Boiler feed pump is part of a closed loop, steam from the boiler after doing work is condensated back to water, and the boiler feed pump returns that water to the boiler to be again be turned into steam, any lose of water ( water condensened from the steam, which shows up as a drop in boiler water level ) is made up to the system from a reserve water tanks.
Regards JD.
Re: What is a Boiler Feed Pump?
08/10/2009 3:26 AM
Register to Reply 3 comments
brkmech (1); jdretired (1); PWSlack (1)
You might be interested in: Boiler Services, Boiler Controllers
