Previous in Forum: Antibacterial Water Soluble Oil with NO SMELL!!   Next in Forum: Constant Cylinder / Water Temperature
Turntable using Pneumatic Actuator
12/12/2006 10:36 PM
I'd like to know for turn table using Pneumatic Rotary Actuator. It will be used for weight upto 250 Kg. Kindly advice me please if you have any type of that Actuator.
Re: Turntable using Pneumatic Actuator
12/13/2006 8:41 AM
check out this webpage to narrow down what you are looking for and to find a list of suppliers: GlobalSpec
Good Answers: 120
12/13/2006 11:39 PM
do you want rotation and at what speed or do you want precise indexing?
Per Ardua Ad Astra
03/29/2007 4:01 AM
I'd like to rotate but no need precise indexing. Rotational speed is about 10~20 rpm.
12/14/2006 11:34 AM
We have used a pneumatic turn table from Festo (festo.com) in several applications and been very satisfied. I believe they come in 3 versions; 4 - 90 degree stops, 8 stops and 12.
The accuracy has been great for the price (under $3000.00) and after several years of running 2 shifts I believe they will still achieve 0.002" accuracy. Not certain if they will handle your weight requirements.
03/29/2007 4:12 AM
I'd checked with Festo supplier. The maximum allowable thrust load is too small. I tried to use thrust bearing. Here, one thing, how many weights can be reduced by bearings? actuator's max allowable torque is 74 Nm at 6 bar. my table is 550mm Dia. so can actuator turn the weight 250Kg using thrust bearing? kindly suggest me please.
aurizon (1); Azeem (2); jstolaruk (1); Nostress (1)
