Previous in Forum: calculations   Next in Forum: Fixed Anchor Bolt for Reinforced Concrete Column
Asphat for Aircraft Runways
08/10/2009 5:28 PM
How can I see one or two typical Asphaltic mix design examples for a runway which is to carry aircraft maximum 60,000lbs. (small aerodrome). Asphalt thickness 50mm.I need something to compare my design with.
Re: Asphalt mix design for runways
08/10/2009 7:19 PM
I don't think you can, "see one or two typical Asphaltic mix design examples for a runway which is to carry aircraft maximum 60,000lbs" here.
08/11/2009 10:06 AM
Thanks,is there a direction you can point me in.As I said I've done a mix design and I'd like to compare.
Register to Reply 2 comments
