Previous in Forum: Impulse Generation and Hydraulics   Next in Forum: water ring vaccume pump overload
Allowable Stress for SA 516 Gr 70
08/11/2009 9:09 AM
Can any body tell me the what is the allowable stress for SA516 Gr 70 as per PD 5500 at 200 degree centigarde?
RK
Re: Allowable Stress - SA 516 Gr 70
08/11/2009 9:22 AM
PG-23 STRESS VALUES FOR
CALCULATION FORMULAS
PG-23.1
The maximum allowable stress values in
Tables 1A and 1B of Section II, Part D, are the unit stresses
to be used in the formulas of this Section to calculate the
minimum required thickness or the maximum allowable
working pressure of the pressure part (see Appendix 1 of
Section II, Part D). ( FROM SECTION I)
Re: Allowable Stress for SA 516 Gr 70
08/12/2009 12:56 AM
S for SA-516 Grade 70 at 200 oC = 138 MPa = 138 000 KPa
See 4 pages of ASME Section II, Part D (Metric Units): ASME_Section_II_Part_D_-_Metric_2004_Edition
08/12/2009 9:00 AM
I agree that 138 MPa as per ASME. But How much allowable stress can be taken as per PD 5500
RK
08/12/2009 9:03 AM
My PVElite program lists 20305.3 psi.
08/18/2009 2:49 AM
17500 psi
05/11/2010 3:20 AM
the value of SA 516 Gr.B is 17500 psi this information is in code? if yes then please specify the link or code name?
Register to Reply 6 comments
Abdel Halim Galala (1); Anonymous Poster (3); atorroja (1); brkmech (1)
