Previous in Forum: Allowable Stress for SA 516 Gr 70   Next in Forum: Vessel Clamp for Highly Corrosive Product
water ring vaccume pump overload
08/11/2009 3:20 PM
Vaccume pump trip on overload but when i throttel vaccume inlet valve load reduced from 25 amp to 22 amp. Why it happens
Good Answers: 19
Re: water ring vaccume pump overload
08/11/2009 11:13 PM
When you move less air, there is less load on the motor. I do not know your layout, but if you have long lengths of vacuum piping, I would suspect leaks in your system that is causing your pump to work harder. What vacuum does your process need, and what vacuum do you operate the pump at to achieve the neede vacuum at the process?
08/12/2009 4:19 AM
we are using flexible hose pipe ( 3 mtr long ) in vaccume pipe and total length of vaccume pipe is 5 mtr. Flexible hose pipe is the requirement of our process we can not replace it with fixed one. the vaccume reqirement of our process is - 20 to -25 psi and we are achiving it even after throttling vaccume inlet valve.
08/12/2009 5:02 AM
That's some vacuum -25 psi?????
Good Answers: 19
08/12/2009 6:32 AM
V,
Double check the units of measurement on your vacuum gage! Maybe it in inches Hg or H20?
Check the pipe to hose connection for air leaks.
If the system works with a throttled valve, you have solved your problem.
08/12/2009 12:06 AM
"Why it happens"
If you don't know why it happens, you should not be adjusting the valves!!!!!!!!
08/12/2009 4:11 AM
vaccume pump were tripping at 25 amp to avoid triping we have to reduce the load that is why we adjusted vaccune inlet valve. And after adjustment we checked vaccume and it was within the range.But i want to know if this will create some problem in future or not.
Register to Reply 6 comments
Anonymous Poster (1); lyn (1); Ried (2); vsrivastava (2)
