Previous in Forum: Transparent Aluminum   Next in Forum: Stainless Steel and Corrosion
Conversion
08/11/2009 10:39 AM
How can I convert 220mg/l HCl to % w/w HCl?
Re: conversion
08/11/2009 10:49 AM
Hint: what is the weight of a litre of water at that temperature?
Good Answers: 101
Re: Conversion
08/11/2009 11:46 AM
1% = 10,000mg/l. Work it out.
Re: Conversion
08/11/2009 2:59 PM
when i titrated manually 1ml HCl i got 3.6%. but when i titrated digital titrator i got 220 ppm? i wanted to know how to calculate w/w % HCL from 220 mg/l they should have the same percentage as 3.6%
Good Answers: 101
Re: Conversion
08/12/2009 11:05 AM
3.6% is 36,000mg/l = 36,000ppm. Check the multiplier scale and the maximum limit of your digital meter. It's the only thing I can think of to explain an error of more than a hundredfold.
Anonymous Poster (1); DVader1000 (2); PWSlack (1)
You might be interested in: Gas Instruments, Gas Sensors, AC to DC Converter Chips
