Previous in Forum: Safe Distance for Diesel Tank   Next in Forum: Spheres and Lathes
8 comments
Worn Bearings
08/15/2009 10:59 AM
i have a junk of worn-out bearing i would like to know is there any way that these bearings can be used or any means to dispose off the completely?
Pathfinder Tags: wornout bearings
Re: Worn Bearings
08/15/2009 3:00 PM
I just toss worn out bearings in the scrap metal bin in my shop.
Good Answers: 243
Re: Worn Bearings
08/15/2009 10:59 PM
If its a roller bearing, the rollers themselves can be used as projectiles with a slingshot for small game and pests. the balance should be recycled, or if you fancy yourself an artist could be welded into part of a sculpture of your own design.
milo
Re: Worn Bearings
08/19/2009 7:58 PM
You meant BALL BEARING ............ right
Re: Worn Bearings
08/16/2009 5:53 AM
There is a limited use for old ball bearing races, only a couple or so of each size. I break them apart save an inner and outer ring these can be used for bearing extractors of the same size where a race has disintegrated in its housing and left the inner or outer stuck in the housing or shaft . Also sometimes use full for fitting in slow moving mechanical items of a non critical nature, I turned some larger ones into machinery skates.
Otherwise break larger ones and give the balls to children to play with they just love them.
Good Answers: 16
Re: Worn Bearings
08/16/2009 5:56 AM
If you are decent with a torch and a welder, you can make some really cool stuff for kids to play on. They wont notice that there is a damaged cup or race, as long as it easily goes round and round its all good!
Re: Worn Bearings
08/16/2009 6:56 AM
Depending on size and quantity, I have seen some great wind chimes made from bearing races. Sold at a fair for $10.00 to $20.00 depending on size
Good Answers: 123
Re: Worn Bearings
08/19/2009 7:21 AM
Make wind chimes out of the outer and inner races. Send the ball or roller bearings to Del the Cat He will be able to forge them into arrowheads.
Bob
Re: Worn Bearings
08/22/2009 7:17 PM
Make a lovely lazy Susan for your significant other.
Nothing exceeds like excess.
Register to Reply 8 comments
Anonymous Poster (1); bob c (1); garth (1); Jaguar (1); Milo (1); tcmtech (1); Tim in Mexico (1); williebinger (1)
