Previous in Forum: Hopkinson Parallel Slide Valves   Next in Forum: Worn Bearings
10 comments
Safe Distance for Diesel Tank
08/14/2009 11:09 PM
please help me in finding standard guiding to choose a safety distance between deisel tank and camp
we intend to built a wall between the tank and the camp
where should we put the wall and how much thick is it?
thanks
Re: safety distance for deiesel tank
08/14/2009 11:38 PM
What galaxy/planet/world/hemisphere/continent/country/state/county/camp are you talking about??????
"where should we put the wall and how much thick is it?"
I have some suggestions where you should put the wall. The thickness should be about the same as yours, very.
08/14/2009 11:43 PM
i am not in USA
it is fuel station
08/15/2009 12:37 AM
what is the relating code that can give guides for installing a fire protection wall to prevent fire to reach camp 8 meter away from diesel fuel tank 50000 liter capacity
the tank is above ground
and the camp is in desert in industrial area
08/15/2009 8:22 AM
Really! Don't expect any help here!
Good Answers: 97
08/16/2009 11:26 PM
Yes as others have indicated a containment basin capable of the entire tank capacity, a 12" poured concrete or block wall earth bermed is an average precautionary rule.
Re: Safe Distance for Diesel Tank
08/15/2009 10:52 PM
hello mostafafealkholy:
Many codes require that the tank be completly surrounded (in concrete) of a size suitable to contain all of the fuel, should the tank ruptue of develope a leak. If the tank is subjected to direct sunlight shading the tank wouldn't hurt even though the tank is vented---Your local codes would dictate distances required between the tank and other dwellings &/or people !
Donzi
Good Answers: 93
08/15/2009 11:16 PM
The wall needs to be taller the closer it is to the exploding 5,000 gallon Truck you have parked temporarily to gravity feed the needs of your Army Camp.
The only real use for the wall when the Tanker is hit, is to direct the force and fire upwards.
Permanent fuel farms bury the tanks.
This does require electricity and pumps and a valve system.
I suggest you put a tank up and fill it and then blow it up to actually perfectly determine where to put your "camp" fence, and how thick you make it.
Normally one does want to be laying on their belly at least 35 yards from major explosions, in my experience.
You don't get wise because you got old, you get old because you were wise.
Good Answers: 38
08/16/2009 12:22 PM
And this guys talking about 26 feet, never mind yards. I hope it's not a sleep away camp!
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
08/17/2009 8:03 AM
In the US we follow the NFPA, state, and federal regulations depending on type, size and fire rating of the tank will greatly affect the distance you can setup a tank from buildings and property lines.
When I design our sites I usually deal with small tanks 1000 gal to 3000 gal. They are usually kept at a 100 ft from any structure or property lines ~30 meters. Plus make sure you have at least a 2 hr to 3 hr fire rating for the tank, check with the manufacturer for it.
John J Baker
09/20/2009 2:32 AM
Yes, this is a dumb question. But for a few of you, does it make you feel smarter to fire back such sarcastic and rude answers?
Register to Reply 10 comments
Anonymous Poster (1); bakerjohn (1); bwire (1); charsley99 (1); donzi (1); lyn (2); mostafaalkholy (2); Transcendian (1)
