Previous in Forum: Control Valve Problem   Next in Forum: Shaft Deflection Measurement
Wanted: Cable for Protovale Covermaster
08/15/2009 4:23 PM
Greetings everyone,
Our lab master has recently obtained a used rebar locater and cannot find the cable that connects the sending unit to the receiver/display. He has called the new distributor and original manufacturer neither of whom would give him any help. They wish to sell him an entire new unit. It appears to need a polarized cable that is coaxial on one end with a four pin connector that appears to use only two pins on the other. Inside investigation revealed #s filed off chips etc that gives almost no indication of how one would correctly rewire the plug. He does not wish to make grave mistake in rigging up a substitute. The unit in question is a Protovale Covermaster, CM4 serial # 59433 that was originally distributed by the Gilson Company. If any knows where to source a cable or knows exactly what we need to fabricate, or even better, has a schematic it would be deeply appreciated. We would even take you fishing if you ever come to Juneau Alaska
Re: Looking for a cable
08/15/2009 5:18 PM
With only two active wires you have a 50/50 chance of getting it right without documentation. If no information is forthcoming you might try wiring it up with a 0.250 amp fast acting fuse and cross your fingers.
Have you tried :
Protovale offers its users support by
telephone +44 (0) 1865 821277,
fax +44 (0) 1865 820573
and email support@protovale.co.uk.
good luck.
Charlie don't surf.
08/16/2009 8:33 PM
stevem
Thank you for your thoughts. We have contemplated gambling that way, but our cowardice has so far prevented that. I believe that contact info is where Dan communicated with but I will try there myself and see if they are willing to help.
Thank you again.
Register to Reply 2 comments
You might be interested in: Rebar, Cable Laying Services, Cable Assemblies
