Re: Linear and Equal Percent Control Valve Application
08/17/2009 5:55 AM
Hi there,
This is not so simple to answer. To truly select the correct control valve characteristic - you need to know the process gain.
As a rule of thumb:
You would use a =% chracteristic on the following process': pressure control
Linear: Level control and flow control.
For a more in depth explanation download the Emerson Control Valve Handbook from www.emmersonprocess.com It is a free download and will explain many more things to you about control valve selection.
