Previous in Forum: Triaxial Cable TNC Connector   Next in Forum: Tank Level Monitoring
Diode Datasheet
08/16/2009 5:02 AM
i have 2 terminal smd (diode) marked CCD PFM . I can not get its datasheet !
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: Diode Datasheet
08/17/2009 12:08 AM
This LINK and LINK should get you started if you want anything outside any usual multimeter test.
Keep in mind that SMD codes are sometimes not labelled to a universal standard.
CraziestOzzy
Re: Diode Datasheet
09/11/2009 1:14 PM
I think it is a 30V 600W Tansorb/Transil (Unidirectional) if I remember correctly.
Re: Diode Datasheet
09/11/2009 2:29 PM
Actually mine is a SMBJ series marked CCD MK which is a 30V 600W Transient Voltage Suppressor.
Search for "SMBJ5.0~171(CCD).PDF" from Taiwan. Yours may be 170V.
Hope this helps because I also struggled !
Register to Reply 3 comments
You might be interested in: CCD Cameras, CCD Image Sensors, Diode Arrays
