Previous in Forum: Diode Datasheet   Next in Forum: Wanted: 4"-Diameter Externally Rated Fan
Tank Level Monitoring
08/17/2009 4:35 PM
I am looking for a reliable way to monitor a 4-20 mA output (from a tank level sensor) remotely without ethernet connection. There is no wireless signal at the location. Currently connected via internet "shoulder tap" system that emails alarms & answers internet inquiry, but my system fails frequently. Does anyone out there have a supplier/system recommendation they are happy with for VMI (vendor managed inventory)?
Re: Tank Level Monitoring
08/18/2009 1:59 AM
One possibility is a cellular modem programmed to call one or more cellular phones in case of failure.
Constant change is here to stay!
08/18/2009 7:53 AM
We're interested in the tank level so we can schedule deliveries when they fit and are needed, or at least the 4-20 mA signal. Merely having a signal that tells us when the level indicator has failed accomplishes nothing. Did you intend to say something more?
08/18/2009 8:28 AM
What is the distance from the tank to you .... Prosoft technologies offers high band transmitters that are designed for industrial use - range to 25 Km and one that reaches 45 km. |Other that that is there a phone line you could use or have installed and then you could monitor from all around the world ....
08/18/2009 8:43 AM
If you have a signal representing level, some very simple electronics and straightforward programming on a small device such as a 'stamp' or an 'arduino' can do it.
level -> signal -> A/D port of the device -> serial (or USB) port of the device -> cellular modem.
Such devices should cost $25-50 and are easily programmed using BASIC or C.
These devices are very robust and self-starting after supply current failures.
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
08/20/2009 9:37 AM
We use a combination of a Gasboy System (for fuel management) and a Veeder-Root (for leak detection. Both send information directly to our home office. They have a wide variety of systems and ways of transporting information.
John J Baker
08/27/2009 12:31 AM
When you say there is "no wireless signal in the area" does that include cell phone coverage. I have a variety of both off-the-shelf and custom solutions using GSM cell phone networks
Register to Reply 6 comments
Anonymous Poster (1); bakerjohn (1); dovy (2); GSM Man (1); Mag (1)
