Previous in Forum: Circuit Breakers   Next in Forum: What is D.C.C.T?
Converter Transformer Secondary Delta Winding - One Phase Shows Zero Volts
08/16/2009 12:26 PM
We had Transformer 11KV/718V/718V (Dd0,Yn5) whose Primary had Delta and Secondary has Delta and Star winding.It is a converter Transformer.I want to know in which case delta winding will show double voltage like R-E is showing 825 and B-E is also showing 825 volts.Y-E is showing zero volts. Transformer rating 11KV/718/718Volts.Please tell in which case Delta winding one phase will show zero volts whereas other windings are showing double voltage w.r.t earth?
Re: Converter Transformer Secondary Delta Winding - One Phase Shows Zero Volts
08/16/2009 5:38 PM
Guest, think about it. How do you get a zero volt to earth potential established for any energised conductor?
If those are real readings, and this is not homework, please let us know, since we will have a lot of good advise for you. CJM
I do not 'know it all', but i will admit that I would like to. CJM
Reply to Forum Thread
