Previous in Forum: Electrical engineer   Next in Forum: Common Mode Choke For AC Line filters
9 comments
Electrical Test Fixture
12/14/2006 8:40 AM
We need test a 37-pin device with the pin length at 0.025", pin diameter at 0.010", pin to pin distance is about 0.05", but can not find a vendor who can manufacture a proper fixture for it, the fixture should be able to clamp the pin but do not damage the pins, anybody have any idea about this?
Re: Electrical Test Fixture
12/14/2006 10:45 AM
What kind of device is this? The device vendor will be able to help you - they test their products all the time.
12/14/2006 1:17 PM
We are the manufacturer
12/15/2006 12:13 AM
Why not make two of the same PC boards, with your spacing requirements, gold plate them, and provide a ribbon cable interface to the rest of your test equipment. The PCboards would be arranged to "bite" onto the pins with spring downforce controlling the pressure of contact. There would need to be guide pins to ensure parallel "bite" and reference stop to ensure correct alignment.
(You didn't say how many items are required to be tested, which will relate to life-expectancy of the test-jig; and you also didn't mention the testing rate)
NeilJ
12/15/2006 12:20 AM
Your best bet is to design it yourself so it will fit to your standards it might take some time but it will be worth it.
SINCERLY,
MAVERICK
12/15/2006 5:31 AM
What does it normally mate with? You can use this to create a functional test or hack the connectors to create an automatic test equipment interface. You might need to give some thought to sacrificial connectors.
12/15/2006 7:37 AM
Thanks for the precious suggestion
The other company will make the mate device, not ready yet. it require IR and DWV test at 600VDC
Safety - ESD - RF Manufacturing ESD Installer
12/15/2006 9:32 AM
I would connect a female end to it and strip it to allow access to the conductors. A neat little trick I've found for testing the female connectors is to clamp my alligator clips on to a paper clip. It has a smaller diameter than the average test lead and seams to read accurately.
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
Mexico - Member - New Member
12/15/2006 11:16 AM
Have you a drawing?
As you say you can wait for the counterpart of your device and test it with it. For sure it will not be design for mass production and you wil have to design a way to replace it easy.
I think the same companny that make the conterpart will be able to make a high volume connector device.
Whoever company that develope fixture will need drawings and for sure they will start with the counterpart of your device :).
Best regards!
Delmar
Knowledge comes from God!!!
12/15/2006 3:59 PM
You can contact me at rwagner@testprosystems.com. We may be able to help you!
Alhuey23 (1); Anonymous Poster (4); bhankiii (1); jowens (1); NeilJ (1); Randall (1)
You might be interested in: Fixture Keys, Clamp Meters, PIN Diodes
