Previous in Forum: Titanium or Carbon Nanoparticles?   Next in Forum: Transporting Cream Across Continents
Helium Properties
08/17/2009 3:30 PM
i was wondering if anyone could provide me with heliums properties such as how much is required to lift a pound or if its not that simple an equation that would provide me how much helium it takes to lift so much and etc. thank you anyone who is helpful
Re: Helium Properties
08/17/2009 3:47 PM
This is a good place to start
http://en.wikipedia.org/wiki/Helium
And here for actual lift values
http://en.wikipedia.org/wiki/Lighter_than_air
9.8 N of lift (the force to lift 1 kg) per cubic meter of gas at room temperature and sea level pressure
08/18/2009 4:51 PM
Regarding the lifting capacity it is simply like this:
Air weighs ~1.29 g/liter and He ~ 0.18 g/L. The difference is ~ 1.11 g/L, meaning 1 Liter of He in air lifts 1.1 gram. 1 m^3 He in air lifts 1.1 kg.
In practicality you must provide a rigid container for the above calculation to work. In case of a formless balloon you must add more He to equalize the pressure inside the balloon with the pressure of the surrounding air, which changes with altitude. When adding more He the balloon gets heavier and less can be lifted per m^3.
In case a rigid 'container' is used, you would not need any gas at all, vacuum weighs the least. Depending on the strength of the "container" you may add some light gas (He) to reduce the strength requirements. It is all a trade-off.
Register to Reply 2 comments
