Hi,
I am currently doing some study on how to overcome condensate found in Instrument Gas on the platform and would appreciate if someone can guide and explain and advise me how to overcome this problem.
Situation :
On the offshore Platform, currently instrument gas are used to run all other downstream equipment such as control valves and actuators. Normally, after the scrubber, only processed hydrocarbon gas(sweet gas) will be channel to run the equipments under the unmanned platform.
However, carryover of water were found with the hydrocarbon gas and thus formed slug which caused demage/trip to the equipments concern.
Solution:
One of the solution tried was to install a filter reg to filter off the excess condensate or water. However that does not gurantee that the instrument gas are fully dry due to the filtering of the water before used by the equipments, we have added a membrane dryer to suppress the dew point further so as to acheive a dryer gas.
Questions:
1) Is there any problem with the scrubber, which can cause carryover of condensate?
2) If installing a filter reg before the point of use, will it get rid of the water condensate, then why are there still condensate found at the downstream or equipments(valves)?
3) With the installing of membrane dryer which can further suppressed the dewpoint temp of water, would it make the instrument gas dryer and solve the condensate issue?
4) With a membrane dryer installed, does it only get rid of the water condensate found in the instrument gas or will it also get rid of some components in the hydrocarbon gas content, which will purge out to the environment, thus causing an envirnomental issue?
Hope someone expert in this field can help.
Thanks.
