Previous in Forum: Vibration Monitoring System ?   Next in Forum: Condensate in Instrument Gas on Off-Shore Platform
DP Level Measurement
08/17/2009 11:40 AM
How can I calibrate a DP type LT, filled with Glycol in the LP and HP side. The closed tank having 50 % of Condensate, The LT HP & LP distance hight is 1.2 mtrs. I need the calibration procedure and formula for the LT.
Re: DP level measurement.
08/17/2009 11:49 AM
The differential pressure due to level is the liquid density multiplied by the height above the sensor multiplied by the acceleration due to gravity. Just scale the unit between 0%/4mA/minimum level and 100%/20mA/maximum level by following the manufacturer's instructions.
Re: DP Level Measurement
08/17/2009 11:28 PM
Please be more specific.
When you say 50% condensate, is that a level or a ratio of mixed liquids (eg condy + water) with a liquid interface?
Do you know your SG or does it vary?
Is the the top diaphragm always in air?
08/18/2009 12:10 PM
Actually I need to select range adjustment ( LRV and URV)of the DP Level transmitter of a Test Seperator ( closed Tank). It is showing 50% Level of condensate on level Glass. And the LP and HP side impulse tube of the LT is filled with Glycol.
filled Glycol SG is 1.05.
10/15/2009 2:59 AM
SG of Glycol is 1.26 isn't it???
08/20/2009 3:04 AM
As you have not mentioned the hight of LT from HP tapping point, I assume it 100mm then calibration of LT will be as below;
LRV= Effective Pressure on LT= Pressure on High side - Pressure on Low side
= (100 x 1.05) - (1300 x 1.05) = 105 - 1365 = -1260
URV= ((1200 x 1.0)+(100x1.05)) - (1300 x 1.05) = - 60
SPAN = URV - LRV = -60 -(-1260) = 1200 = distance between your HP & LP Points
Hope this clarifies your question.
Regards,
Best Regards, srzambre.
01/13/2011 1:23 PM
what is 1300, 1200 &100
Anonymous Poster (3); muzza (1); PWSlack (1); srzambre (1)
