Previous in Forum: Ultrasonic Thickness Measurement   Next in Forum: Peak Combustion Temperature
Pressure & Gas Thermal Conductivity?
12/14/2006 3:22 PM
Does the thermal conductivity of a gas improve with pressure?
Thanks!
Good Answers: 137
Re: Pressure & Gas Thermal Conductivity?
12/15/2006 4:30 AM
According to data I have, it increases with pressure, but slowly, << proportional.
At 0°C - 1 bara, k = 0.238 kcal/kg/°C, at 100 bara, k = 0.298 kcal/kg/°C, approx linearly in between.
Heat Conduction of Helium 1-200 atms?
12/15/2006 6:01 PM
Thank you so much for the answer you already posted!
Specifically, I need information on helium between 1 and 200 atmospheres. Also, how should I be looking this sort of information up. I have been going in circles trying to find it!
Thanks Again!
Scott
Re: Heat Conduction of Helium 1-200 atms?
12/16/2006 1:33 PM
This is codemaster, on another computer and can't get it to log in.
Re earlier posting - I gave data for specific heat, not thermal conductivity, and for air, whereas question just said gas. Profuse apologies! should have read it more carefully.
If I can find anything about thermal conductivity of helium vs pressure I'll get back on.
Good Answers: 137
12/18/2006 9:57 AM
Only data on helium I can find says ~ 0.15 watt/m/K at room temp. Data given over temp range from 0.08K (k = 4.4*10-5 watt/m/K) to 5000K (k = 1.27 watt/m/K)
It doesn't say at what pressure, or mention variation with pressure, suggesting it's independent of, as noted by Marcial.
12/15/2006 10:51 AM
Except for high vacuums, the thermal conductivity of a gas is not affected by pressure- Kern, Process Heat Transfer.
Anonymous Poster (1); Codemaster (2); Marcial (1); scott712 (1)
