Previous in Forum: Step Cooling in Alloy Steel   Next in Forum: Resin Bead Treatment
Thermosets
08/18/2009 2:04 PM
is there a reliable thermoset out there that can handle 350C conditions for periods of 15-25 hrs?
Re: Thermosets
08/18/2009 2:08 PM
You mean a thermoset plastic? Why does it need to be a thermoset?
Re: Thermosets
08/18/2009 2:19 PM
i need a material that will deflect about 1/17th of an in under low pressure, in 350C.
Re: Thermosets
08/18/2009 2:48 PM
Double,
If you expect any kind of answer, you need to do some work and give a lot more information!
1/17in deflection over what distance?
Where are the tie points?
Is there a thickness requirement?
Is there a weight requirement?
Is there a color requirement?
Is there a finish requirement?
If I work in a chemical plant doing hydrogenation reactions, low pressure to me would be 100psig. If I made differential pressure transmitters, low pressure would be 0.25 inH2O. So how low is "low pressure"?
Is there an reason it cannot be a metal or ceramic or glass?
Mike
Re: Thermosets
08/18/2009 8:04 PM
No. What else do you want to hear? Ain't gonna happen. No way. OK?
Good Answers: 15
Re: Thermosets
08/25/2009 4:00 AM
Hello,
Try Vespel Polyimide material heat deflection temp is 360 degrees.
www.matweb.com type in Vespel. Try high glass loadings and see the results.
Good luck
I like 2 tinker-no, really!
2tinker (1); Double (1); lyn (1); Mikerho (2)
