Previous in Forum: Earthing System of DG Sets   Next in Forum: Sensors for Cotton Ginning
Alternator Conversion
08/20/2009 2:04 AM
Please help me. I have a 100kVa gas genset at 200volts line to line and 110volts across line to neutral.I want to convert it into 400volts line to line and 220volts line to Neutral.What changes would be made in windings
Good Answers: 103
Re: Alternator conversion
08/20/2009 2:10 AM
Instead of complicating, use a transformer. That may come out cheaper than changing the windings, field and other C&I.
08/20/2009 2:45 AM
ya!!!!!!!! transformer is good solution.........
08/20/2009 4:29 AM
Yes,
Just go for an 200 V to 400 Volt, 100 kVA step up transformer.
This will be an easiest solution.
08/20/2009 5:51 AM
Depending what brand of generator you have, it might be possible to change the connection on the terminal block to give the desired voltages.
Some manufacturers bring out 12 leads to the terminal box of the generator. By changing the connection in the terminal box will change the output voltage.
R T F M .......
08/22/2009 12:51 AM
But How these connections will be changed..?I think that there will be a need to make them in series instead of keeping parallel..what do u suggest?
Aldego (1); anbarasu.pr (1); riazzee (1); saropowervolt@gmail.com (1); sb (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
