Previous in Forum: Delta Star Transformer   Next in Forum: Alternator Conversion
Earthing System of DG Sets
08/20/2009 1:54 AM
Is it necessray to provide seperate earthing wires to the auxilary motors for pumps etc. installed on the common earthed frome of the Dg set of 4 Mw, slow speed.
Mankotia P.S.
Re: Earthing system of DG sets
08/20/2009 3:15 AM
If there is a risk of corrosion taking place between the metallic faces of the parts bolted together, or if there is the risk of a paint layer between them, then almost certainly. There needs to be a level of redundancy in earthing systems.
08/22/2009 8:32 AM
And of course,
if you want to reduce the earth fault energy at places around aux. equipments, which are fed thru a seperate breaker.
Also, max. fault level is at the alternator body earthing.
Exploring the Science of Electricity
Register to Reply 2 comments
You might be interested in: Die Sets, Hookup Wires, Conveyor Rollers
