Previous in Forum: Transformers and Secondary Voltage   Next in Forum: Earthing System of DG Sets
Delta Star Transformer
08/20/2009 1:49 AM
what would happen to secondary voltages of the delta star transformer if one of the phases on the primary side goes off (i.e. supply to that phase gets disconnected?)
Re: delta star trnasformer
08/20/2009 3:16 AM
The secondary output will drop too. Possibly some of the circuit protective devices will operate.
It is more likely that two phases will go, and not one, on the primary side. If that happens, the secondary output will drop to zero.
Good Answers: 244
08/20/2009 9:49 PM
Please see the following thread, it may help.
http://cr4.globalspec.com/thread/40007
-MS
Good Answers: 32
Re: Delta Star Transformer
08/21/2009 10:08 AM
I had a Delta wound transformer supporting our 220-3 phase secondary system and the utility transformer blew a link up on the pole. Our 3 phase machinery slowed down noticeably, some popped off and we quickly shut all the 220v-3 phase down before the rest could overload. We lost a 220 single phase on the boiler circulator because no one remembered that it was on 220.
On a Delta wound transformer each leg only carries 57.7% on the current on each leg. It tends to balance out the loads on each leg. However, when you lose a phase you now have an "open Delta" and the system can't support the full load.
Another time we lost one of the three 100A fuses at the disconnect protecting a Delta wound Transformer with the same resulting slowdown of machinery. Fortunately we had learned our lesson from the first incident and saved everything that time.
Spinco
Register to Reply 3 comments
msamad (1); PWSlack (1); Spinco (1)
