We are currently having problems in our manufacturing department with a nozzle we make. The part is first cut to length and drilled from both ends (diff. dia. Drills from each side) to make a blank. The blank is then swagged twice, first to form the outside shape and resize the inside diameter holes, second swage is to make the I.D.'s even smaller, around .027" tapered down towards the flame end. Our problems are the following: 1) The TIR of the center hole is averaging .015"-.020" and the tolerance is .008". 2) Also, we are getting 2-3 degree angles coming out of the flame (small) end, which we believe is resulting from a "wormhole". How could we possibly tighten the TIR and Angle of the center hole in our nozzle?
