Previous in Forum: Air Engine   Next in Forum: Control Valve Sizing
HP Steam Turbine Shaft Seals - Shutdown Condition Sealing
08/21/2009 8:36 AM
Regarding large steam power plant high pressure turbines: Any ideas on flow resistance/pressure drop through turbine shaft seals under shutdown conditions (i.e., no sealing steam, turbine not spinning)?
"For a successful technology, reality must take precedence over public relations, for nature cannot be fooled." -Richard Feynman
Re: HP Steam Turbine Shaft Seals - Shutdown Condition Sealing
08/21/2009 9:13 AM
If there is no flow under shutdown conditions, then there will be no friction at the boundaries of the control volume with which to create a pressure drop. So the answer in this case is 0.
08/21/2009 9:48 AM
By definition.
But the question is if there is some amount of above atmospheric pressure on the turbine internal side, what would be the flow out the seals. Conversely, if there in vacuum inside, then the flow in.
Experience preferably, and as a worst case, experimental or analytical approach, used or useful, is what I'm looking for.
08/21/2009 10:28 AM
"Stopped though still hot"?
The pressure drop can therefore be determined by observing the pressure gauge closest to the equipment in the steam supply line. In comparison with the pressure drop through the turbine when the thing is running, the drop through the turbine itself is negligible with it stationary, nearly all of the drop happening across the seal.
08/21/2009 10:46 AM
Definitely stopped though still hot, probably complicating things.
I'll look for the nearest gauge. For outleakage, to estimate the flow we'd have the figure out the source free volume and time its pressure decay, probably complicated by some cooling or condensation that is going on. Inleakage has similar issues, since vacuum could be lost in other ways.
Maybe cold condition assessments would be simpler. But it still would be nice to know if anyone has done a simple, cold, controlled experiment or a design analysis for such a seal system.
Maybe a call to a manufacturer would yield something.
Good Answers: 32
08/21/2009 11:03 AM
Most steam turbines exhaust into a vacuum for greatest efficiency. When you shut down that turbine all main valves are closed. No positive pressure in the system. On most systems even if the turbine is off-line then you maintain vacuum on your system to keep it warm and you use sealing steam to keep air out of your system. Steam turbines use to use labyrinth seals(probably still do), where the steam under some pressure above atmospheric is introduced into a middle area and flows inward to be condensed and outward as a slight positive flow(weep-age) to prevent air from being drawn in. Air leakage into your vacuum side is a no-no. Cold starts are a drag and excessive condensation in a cold start can create havoc to rotor blades when that moisture starts zinging through the blades, reversing directions and vibrating the hell out of things.
So, A) a positive pressure by means of sealing steam MUST be maintained and the leakage would be calculated by the steam pressure at the seal and the restictive orifice area presented by the labyrinth seal and the shaft. Good luck on that!!! B) Flow in-Bad Idea!!! Should only happen on a complete shut down for major repairs to turbine or condenser.
Spinco
08/21/2009 12:35 PM
I think, but I could certainly be wrong, that during a typical two to four week outage that you will have lost vacuum. And that you would be using mechanical vacuum pumps to re-establish a condenser (and turbine?) vacuum, maybe before introducing heatup steam. Big volume calc here, and the assumption that inleakage to the whole system is from turbine seal inleakage. Of course both HP and LP seals turbines would then be involved at that point.
Definitely agree on issues with respect to labyrinth seal flow orifice equivalencing. I guess that might be what I'm looking to be handed to me from experience or prior analysis..
Good Answers: 32
08/21/2009 1:31 PM
During a 2-4 week shut down the vacuum would be broken, sealing steam shut off, turbine drains opened, condenser and condensate pumps off and interior would be at atmospheric pressure, hence as the man said before Flow=0.
On start up sealing steam turned on to maintain wisps of OUTWARD flow, warm up steam introduced so it's blowing out any condensate to the turbine drains, steam eductors or vacuum pumps turned on, condenser and condensate pumps turned on. When there is no evidence of moisture from the drains and the vacuum is sufficient the drains can be closed. It is the sealing steam into the labyrinth seals under positive pressure that keeps any inward leakage from occurring. Once the vacuum has been established and the turbines are on line your vacuum system should only be removing minor amounts of air.
Your hypothesis of huge volumes of inward leakage basically surmises that your labyrinths are shot and no amount of sealing steam can keep the air out (or that you have a crack in your condenser or turbine housing) so you're the creek without a paddle anyway. Please do not attempt to start up a plant on the above instructions.
Spinco
Register to Reply 7 comments
N&P (3); PWSlack (2); Spinco (2)
