Previous in Forum: disconnect power   Next in Forum: AC Shunt Properties
21 comments
Inverter Efficiency Errors
08/22/2009 10:04 PM
Before I start, for those who have posted that it is cheaper to go out and buy an inverter rather build your own, it entirely depends on which part of the world you live in. The total cost of parts for a 2000 Watt Sine wave inverter outside of "developed" nations is roughly $30.00 USD.
We are doing some solar power system design and decided to look at pricing of panels all over the world. If you live in Canada, boy are you getting fleeced! Check this out. Solar Panel Canadian Tire 80 watts. You can get one 240 panel for $432.00 USD. It would cost you over $2000.00 for the equivalent amount of wattage. No wonder North Americans have to mortgage their homes and live off credit cards!!!! If you guys don't start manufacturing your own stuff soon... but that's for another forum.
Here's the info we wanted to share. We had a tech do some efficiency calculations on a 300 Watt inverter, 12VDC in, 115VAC out, 60 Hz. He came back with efficiencies over 100%!!!! Here's why.
The DMM gave a 124 VAC reading. When the rated 115 VAC inverter voltage was used, it was still showing over 100% efficiency.
After looking at it on the scope and calculating the actual pulse width, we quickly dispelled the over unity theory and produce a realistic and acceptable 85% Efficiency.
Re: Inverter Efficiency Errors
08/22/2009 10:12 PM
And?
08/23/2009 3:47 AM
A DMM won't give correct AC voltage reading on a square wave, but I expect you know that....
Not sure if you are asking or telling...
Still it's more interesting than some posts
08/23/2009 4:33 AM
We are telling, just sharing some information on the subject should anyone else get puzzling results.
The test was done on various inverters, including pure sine wave inverters. Getting one such set of results seemed too good to be true.
There were a lot of things we didn't know about these inverters though. The most important thing we discovered is that when they go into alarm mode (beeping sound), they draw maximum current from the batteries, in this case 2.6 Amps. A particular brand would also draw over 2 amps in when first turned on. But instead of dropping back down to meet the load it was carrying, a 1.4 Amp load, it remained at 2.2 amps with no alarm indication. It had to be cycled on and off a few times before it went down to 1.4 Amps.
So for smaller systems where you are not getting anywhere near the performance from your batteries, the inverter could be the culprit. For systems that don't have a low voltage cutoff, some of these inverters will rapidly drain your batteries beyond 80% DOD.
Also when more than 1 inverter is used, the current draw from each inverter when carrying no load has to be factored in. These small unit draw 0.110 A while larger ones draw up to 5 amps when no load attached. This information was stated anywhere by the manufacturers.
We will be looking at dedicated 'solar' inverters next month to see how they operate.
Greenja
08/23/2009 11:47 PM
Solar panels (modules) are usually sold per watt or at least comparisons are made based on price per watt. Most panels in the States ARE cheap at $3.50 to $4.50 per watt price. In Argentina the same panels run in excess of $9.00 to $10.00 dollars per watt and you wonder why developing countries take so long to develop! (Import duty runs 50% including shipping). I really don't think anyone can make a pure sine wave inverter for less than they are sold in China! The last one I purchased on E-Bay was U$S 135.00 for a 1200w / 2400w surge pure sine wave inverter with most bells and whistles included.
08/24/2009 2:43 PM
First - Welcome to CR4!
Second - Why did you mark it Off Topic? Seems right on to me!
It seems that all governments, including mine and yours, have short-term goals in mind when determining taxes...
08/24/2009 3:31 PM
Thanks for letting me know your thoughts about off topic. I just discovered this forum a few days ago and wasn't sure how close the answers need to me to the topic. That was my first post and thought it might help someone. You are right about governments. Seems like they are a necessary evil to me. I'm a third generation Californian who escaped back in 1992 at the end of the cold war to Argentina's Patagonia region in the south. (Fewer people fewer problems).
I was working for TRW on high energy chemical lasers and rocket engines at a remote highly secured test site behind San Clemente, Ca. for nearly 20 years.
To me, modified sine wave inverters are only good if used for a specific service otherwise the problems with noise and failures are problematic. (Generally motors have a problem with the square wave and to a lesser extent electronics can be affected by noise radiation from the inverter). I don't recommend them for general use but they have their use and they are much cheaper than sine wave inverters. The 1200w / 2400W pure sine wave inverter I mentioned for $135 from China seems like a good deal if the parts hold up! Will know shortly.
I am looking for a 6 or 12 volt DC solenoid for another project that can act directly as a hammer would this forum be a place to see if anyone knows where to find one? I don't have specifics yet as to foot lbs of energy but it would be high to replace the firing pin and spring similar to that found in a gun to strike a shotgun shell. This is part of a project to capture migratory birds for banding. (Deploy a huge net via cannons). My present design is unreliable because the present solenoids don't have sufficent energy to fire the shell every time eventhough I tripled the voltage to them.
08/24/2009 4:20 PM
How about compressed CO2?
Good Answers: 119
08/24/2009 6:49 PM
What you want to do takes a fair amount of stored electrical energy. Examine an electric nail driver for basic concept.
I've worked on similar projects and have tried direct acting (impact) and fast arc (thermal) primer firing methods. Both of these required energy storage in large electrolytic capacitors and large SCR switches to reliably ignite the primers. Not very easy or portable.
I recommend you find normal firing pin mechanisms that are manually "set", then triggered by small solenoids or servo motors. Also try to add or implement some safety devices or procedures so no one gets injured.
Be safe!
08/24/2009 8:55 PM
Safe indeed! Tell me if I need to start a new topic for this. I was commenting as off topic but now it doesn't look it...??
Re: capture system: I designed and built two cannons that fire simultaneously projectiles that weigh 8Lbs each. These in turn are connected to a 10x17meter net that covers the birds in a fraction of a second before they can escape. I am using a two meter radio to remote fire the cannons because people nearby will scare the birds. Safey isn't much of an issue. Compressed air might be great using small CO2 cylinders but again a fast acting valve is required. I have battery power available (typical lead acid emergency light battery). A valve that is too slow will tend to push not hammer the firing pin into the modified shotgun shells primers. (they hold a lot of extremely fast burning pistol powder). I actually had some success using firecrackers electrically set off to drive a piston inside a tube with a pin to strike the shells and it worked but again not reliably. The force of a standard trigger/spring mechanism is really high and so far hard to duplicate with a solenoid. Not to worry this project doesn't have much priority but I would like to solve it one day. I have been working with Dr. Alan Baker of the Royal Toronto Museum as he is head investigator into the Red Knots. (www.rom.on.ca/media/magazine/spring09.php) in solving ways to capture these guys for banding.
The proper soleniod that has a heavy core and fast enough to use it's "core" to bang into the shell would be most simple approach I think. Thanks for the comments.
Good Answers: 119
08/24/2009 9:21 PM
If you want feedback from a larger audience, I don't see any problem with starting a new thread about this topic. I can't provide any further details about my project, but you may find other responders with useful suggestions. Best wishes.
08/25/2009 1:05 PM
"To me, modified sine wave inverters are only good if used for a specific service otherwise the problems with noise and failures are problematic."
I have a Radio Shack 12->115V 350W inverter for my car. It's a modified Square Wave type (it doesn't say; I had to 'scope it), and I have used it with no problems to power 120V lights, my soldering pencil, and my MacBook Pro for quite a few hours.
I was fortunate to spend 2.5 years in Chile with the Peace Corps back in the '60s, and did manage to see some of Patagonia (I saw the Torres de Paine for about 30 seconds, through a hole in the clouds). I was within a few hundred meters of Argentina in several places, and did step into Argentina at the pass above Portillo (on the old road, now a tunnel). Some day I'll see more...
Good Answers: 119
08/24/2009 12:45 AM
The waveform shown is from a simple "modified" sine wave inverter. NO ONE should ever trust power and efficiency calculations based solely on DMM measurements. Precise voltage and current waveform measurement is the only reliable method. The 85% efficiency calculation seems realistic.
For reference, I regularly see 350W inverters for $25. Just last week I passed up a 2000W inverter that was on sale for $120 (I just don't need one right now).
Regarding your proposed 2000 Watt Sine wave (true Sine?) inverter design:
All electronic parts (including power and protection components), fans, PCB's, chassis, terminals, wiring, and magnetics for $30 ?
Having worked in the electronics design and manufacturing industry for ~20 years, I believe your $30 parts cost estimate for a 2kW inverter would require large volume parts pricing. Fine for a company, but extremely difficult for the average electronics hobbyist.
If you can design, manufacture, and sell your 2kW inverter at a profit, you should do it!
08/24/2009 2:01 AM
I got a real eye opener while in the Caribbean. The fans, terminals, plugs are so inexpensive I had to check to make sure they were actually made out of plastic and not sugar!
Apparently there is so much over capacity right now and the fact that the middleman is pretty much eliminated, you get the parts for the manufacturers asking price. As far as approvals UL, CSA they all have both. Component cost and IC are very cheap. I'm assuming it has more to do with shipping cost than anything else, the shipping cost has to be passed on to the consumer. Also we found out that these manufacturers produce equipment for several major names, all on the same assembly line so the components are coming from the same place.
We are cautious and do a lot testing before we recommend or install the equipment at sites. Our primary concern is how well the IC do during electrical storms, lots of zapped equipment out here which is not entirely the fault of the equipment, but the lightning protection of the buildings.
Greenja
Good Answers: 15
08/25/2009 4:28 PM
Hi Greenja,
the inverter efficiencies are well known, as are the mis-reading of "modified sine" waves with non TRMS meters. I get a couple of calls a year from new yacht crew who read the meters on the panel and see typically 185V in place of the expected 220V. I, in my honesty and lack of business sense, take along a TRMS meter, demonstrate the real RMS value and then try to sell them a sine wave unit!
These modified square (I prefer that to modified sine) waves normally have a peak of about 1.414 x the rms therefore I would have expected about 160V for a 115V inverter. However as the battery volts drop with discharge the peak volts drop and the pulse widens to compensate to maintain the rms 115V. They normally cut off when they can no longer maintain the 115 or 230V which is when the waveform has deteriorated to a square wave.
These inverters will run almost anything however when the peak voltage drops some appliances will not run (microwaves being a typical example). This computer and its peripherals, the sat TV, our low energy compact fluorescents all run flawlessly with a mod'd square. The water pump runs a little noisily and normal inductive ballast fluorescent lights usually will not run or stop when the peak starts to get low.
Regards
Chas
08/25/2009 6:10 PM
Hello Chas,
There were no problems with the mod square wave inverters in terms what they could power. We were a little disappointed when we discovered their shortcomings though, that is excessive current drain when no alarm was present. The only way to know if there was a problem was to meter it. I suppose an analog amp meter in the setup would be a good idea.
We did notice the extra noise coming from the fans. It appears that the fans are running faster than when connected to the AC line. Not sure if the extra noise is from increase fan speed or due to the mod square wave input. We will have to do an RPM measurement on them to find out, then run them at the equivalent AC voltage that produces the same RPM as the inverter.
Greenja.
Good Answers: 15
08/25/2009 7:03 PM
Hi Greenja,
the noise you are hearing is probably the effect of the high frequencies present in the waveform. Effectively you are trying to jerk the rotor around instead of pulling it smoothly.
The high power draw you sometimes see is most likely the result of a faulty unit. I have never encountered this in twenty years working with inverters, however I am normally only working with the established big name brands.
One problem with inverters is they are a little like a jet engine. If you don't get it right first time they have a high predisposition to blow up! One problem with most brands is repair-ability. Most manufacturer's won't give out schematics, for the reasons above, and as surface mount and programmed chips are used it makes them almost unservicable except at the factory. That is maybe the only reason for building your own.
Patagoniakid's remarks are no longer true. Older sine wave units made square waves and then filtered them to sines with big inductors. This made them very inefficient and noisy. Modern sine techniques have a slightly lower efficiency than the mod'd square but the motors work more efficiently with it.
kind regards
Chas
08/25/2009 9:06 PM
You are right about not being able to repair the units easily. Some of them sand down the part numbers on the IC, MosFets and Diodes.
Measure the current draw when your inverter goes into alarm mode, if it does not have a low voltage cutoff. Our results came when the batteries were just at the threshold, 10.5V. Then the inverter would go into alarm, draw high current and then just completely drain the batteries as it pulsed in and out of alarm mode.
The part about the old sine wave units making square waves still applies to the modern sine wave inverters. The older ones made a large square wave(mod square wave) and filtered it to a sine wave. The modern inverters make a lot very small square waves (PWM high frequency square waves) and filter them into a sine wave (low pass filter).
We are testing a few designs of single phase inverters using Maxim Mosfet drivers, MC908 micro with Maxim battery charging ICs. So far most of the problems encountered by the smaller units can be eliminated through code.
Greenja.
Good Answers: 119
08/26/2009 12:25 AM
I think your testing has identified the problem. Some "cheaper" modified sine inverters either completely lack or have poorly adjusted overload and low battery alarm/cutoff features. These safety/protection features NEED to be present and working correctly for all applications.
I would expect/want a low battery alarm warning to start sounding at about 11.5 V and a complete shut-down to occur when the battery voltage dropped below10.8V. IMHO, a well designed inverter would allow the user to adjust these thresholds to slightly higher levels to prolong battery life.
Good Answers: 15
08/26/2009 6:45 AM
Hi Greenja,
I think the unit you have is either faulty or at the bottom end of the market because all the units i deal with would normally cut out at that voltage, specifically to stop the fatal drain on the battery. They should also latch off with a hysteresis reset of >13V so that it will not switch on until the battery has received some charge. The symptoms you describe indicate a very small hysteresis, as it seems it is dropping in and out of operation as the battery volts recover.
Modern sine wave units do work on a pwm principle but it is not like the old low frequency units. They don't filter away the HF components, they integrate the pulses which means the energy is not being wasted.
regards
Chas
08/25/2009 9:25 PM
Unless something changed in the last day or so you will find modified sine wave or square wave inverters are not the total solution. There are problems with them that can be offset by price depending on the application. They are cheaper but that is where the comparison ends. I will still go on the record not recommending such inverters unless it is for a specific use that is known to tolerate such a wave form and you are willing to pay the price in inefficiency.
Current information (non technical) can be found here. I rest my case. They work fine but not as efficiently for more than 90% of the cases but...
You will find what doesn't work well with modified sine inverters listed here:
http://www.donrowe.com/inverters/inverter_fag.html#modified
http://www.eirbyte.com/inverters.html
http://www.energymatters.com.au/renewable-energy/inverters/
http://www.windsun.com/inverters/inverter_selection.htm
It really comes down to price and what you are willing to accept from the inverter. Recently I have seen pure sine wave inverters really cheap. Check e-Bay and avoid the modified sine wave problems....I rest my case.
Patagoniakid N6EXQ
Good Answers: 15
08/26/2009 7:39 AM
Hi Patagoniakid,
Firstly, my apologies, I mis-read your first comment. I thought you had written that the sine units were inefficient a compromise, and so my remark was unfounded.
The modern PWM sine wave inverters are a little less efficient than the modified square wave in terms of energy conversion from battery to 230V or 115V so to use for a resistive or rectifier load (smps power supplies) they are actually still better.
Apart from the items mentioned previously the other main failing of these units is that on some domestic equipment (eg washing machines) with program functions the power supplies for the electronics are derived from a simple capacitive dropper /resistor/ zener circuit which is designed to work with a sine wave of a fixed frequency. The HF present in these waveforms passes too much through the cap and it burns out the resistor or zener after a short time.
I run my house from a modified square unit but I only sell sine units.
Entonces tengo la firma al fondo de los comentarios míos. ¿No sé si les usan lo mismo frase en Patagonia como en España?
Saludos
Chas
Register to Reply 21 comments
capblanc (4); dkwarner (2); Greenja (5); mjb1962853 (4); Patagoniakid (4); tcmtech (1); user-deleted-1105 (1)
