Previous in Forum: Inventors   Next in Forum: Regeneration of employment in U.S.A.
pressure leak
08/23/2009 10:37 AM
want to check leakages in plane diametrical shape plate, three pipes of dia 10mm welded @ 120 deg and on 100mm pcd, plate size is 160 mm dia and base chamber dia is 150 mm , Pressure applied is 0.5bar ,
base chamber surface area 150mm dia,\
chamber pressure 0.5 bar,
clamping cylinder area 80mm dia pressure 5 bar,
any idea
Re: pressure leak
08/23/2009 1:08 PM
Hi Jarun Magnet , do you have a sketch?
Or a CAD drawing?
or send it to my email
myusernamehere at gmail.com
devitg
Good Answers: 58
Re: pressure leak
08/24/2009 7:49 AM
I suggest you obtain a book on leak testing. American Society for Nondestructive Testing has a good one. You must first have an idea what size leaks you are trying to detect. Conventional leak rates are measured in atm cc he/sec and cover about 12 decades. There isn't any one instrument that can cover the entire range of possible leak rates. If you ask a more specific question, we may be able to give you a better answer.
Register to Reply 2 comments
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
