An engineering friend/co-worker recommended that I appeal to the CR4 website for advice.
I have a 1998 Chrysler Town & Country LXi with transmission trouble.
Chronology of events:
1- "Service Engine Soon" dashboard light comes on.
2- Transmission won't up-shift to third gear.
3- Mechanic says it's "the" speed sensor. Didn't specify which one. Speed sensor
replaced; no change.
4- Fault code says, "Shift Solenoid C Malfunction." Mechanics advises replacing solenoid
pack. (Kind of expensive; wondering if the car is worth it.)
5- Through trial and error, I discover that the problem only happens when the engine is
warm. A blogger advises that sometimes a solenoid just "sticks." I should try TransTune
to un-stick it.
6- TransTune doesn't help, but now I have to get the fluid replaced anyway. Mechanic
says the transmission fluid was black, even though we both agree it was a healthy red
only days ago. Also claims the filter was just hanging; not securely attached. Problem
still persists.
7- Mechanic insists it's got to be the solenoid pack. I protest that if solenoid C were
bad, then it should be bad all the time, instead of just when the engine is warm. He
counters that it could be that when the engine is warm, there could be an intermittent
break in the grounding connection. I counter that if that were the case, then all of the
solenoids should malfunction at that point and the car should default to neutral.
8- A blogger says that if the onboard computer senses that the transmission is operating
too hot, it will shift to "limp mode" to protect the transmission. Mechanic does a
half-hearted investigation of the heat exchanger, claiming that this can't be the
problem because there is a separate fault code for just that kind of problem.
Any advice on what my next move should be?
(Other than put a "For Sale" sign in the windshield.)
