Previous in Forum: 1998 Chrysler Town & Country LXi transmission trouble   Next in Forum: Stall on my Polo Golf Model 1996 Car
Early 01 Volkswagen Passat brake problem.
08/23/2009 12:50 PM
Ok, bear with me here. Quite some time ago I was driving down the road and brake failure lights came on on my dash. I pulled over and tested the brakes on the side of the road. Noticed no degradation of performance of the brakes so I drove the car home. The warning lights intermittently would come on and off seemingly randomly. I realized it had been quite a while since I replaced the pads so, not having the time to do it myself, I took it to Mineke. They kept the car a day and said I needed
rotors and pads. I Ok'd this and they replaced them. The brake warning lights did not go off. I mentioned this to Mineke and they said I may need to take the car to Volkswagen to get them to turn the light off. I have not done this yet because it appears to be just a nuisance. Now, however, the brakes are scrubbing. I have pulled the brakes apart and found that nothing obvious is wrong. Pads are still good, rotors are smooth and unworn. Caliper piston is not sticking and it's getting brake fluid from the brake lines. The car stops just fine but there is a constant scrubbing or grinding as if the pads are not releasing all the way after I apply them. I haven't driven the car much since the brake problems began but need to get it running now.
Re: Early 01 Volkswagen Passat brake problem.
08/23/2009 2:25 PM
This may sound silly but is there a small rectangular "dust cover" at the top of the caliper? If so take it off and see if the noise goes away.
CARPE CRUSTULORUM!
Good Answers: 123
08/25/2009 11:18 AM
Could the inboard brake pad be installed backwards on one or both sides?
Can you determine which side the scrubbing is camming from?
Have you been able to feel one side of the car's wheels getting hotter than the other?
Have you contacted Mineke yet?
Bob
08/26/2009 4:58 PM
Buy a VW shop manual (from Helm or the dealer) and go through the procedure to identify brake problems. If this car has ABS, follow the manual's suggestions to discover whether it is working properly. If you are not mechanically inclined, a visit to a VW dealer or an independent garage that repairs VWs is the most cost efficient solution.
Dennis Waller
bob c (1); DennisWaller (1); not so smart (1)
