Previous in Forum: Protection With CBCT   Next in Forum: can somebody suggest a good book for power systems?
KWH (UNIT)
08/24/2009 3:27 AM
HELLO EVERY ONE
I HAVE 57 TONES OF AIR CONDITIONER (A/C) ,NOW I WANT TO ASK IF I USE THIS ALL A/C FOR 10 HOURS ,HOW MUCH KWH CONSUMED ,THANKS
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: KWH (UNIT)
08/24/2009 3:32 AM
SHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!<Splutter>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 103
Re: KWH (UNIT)
08/24/2009 11:08 AM
There is bound to be an electrical rating on the AC. From the TPH it is not possible to calculate the KW consumed.
It depends on the
- Efficiency (now being denoted by the mandatory star ratings)
- The Ambient temperature.
- The Insulations.
- The Set temperature.
And the consumption is going to vary across seasons. In the worst case scenario, get the electrical KW x 10 Hrs is the unit consumed per day (?)
Good Answers: 244
Re: KWH (UNIT)
08/24/2009 8:28 PM
A rough approximation:
Using the rule of thumb: 1.25 KW per Ton,
Energy Used = 57 x 1.25 x 10 = 712 KWH
Again, this is just an approximation, the actual consumption depends on many other factors as other participant indicated.
- MS
Re: KWH (UNIT)
08/25/2009 1:11 PM
hi mr.dineshpandit
we can calculate by using the below formula
watts*3.4=BTU
1 ton = 12000BTU
57 ton = 684000BTU
watts = 684000/3.4
watts = 201176.47
KW = 201.176
kwh(10hours) = 201.176*10 = 2011.176
regards
uticobala
Re: KWH (UNIT)
08/25/2009 9:32 PM
Msamad's calculation is close. Here is a good calculation procedure http://joule.bu.edu/~hazen/LinuxCluster/actut.pdf
Uticobala's calculation is ok but it doesn't consider the Performance Factor (K) and that is why it is higher.
Also see the example here
http://wiki.answers.com/Q/How_many_watts_does_an_air_conditioner_have
Anonymous Poster (1); msamad (1); sb (1); Stinky Pete (1); uticobala (1)
