Has anyone investigated the possible combination of cavitation under extremely high pressure (1Kbar+) in combination with high-current passing thru water?
Cavitation produces temperatures as hot as the surface of the sun, in addition to extreme pressures even at atmospheric pressure. Add electrolytic splitting of hydrogen, and we could possibly achieve an over-unity device (fusion), as the freed hygrogen is compressed when the cavity implodes, or more heat as the hydrogen and oxygen recombine under the pressure.
Perhaps the current would have to be synchronized with the cavitation frequency?
It would require a very high power ultrasonic transducer to produce cavitation under these conditions.
I do not have the required equipment or money to try this, but perhaps someone will.
All I have in an idea.
Or maybe this has been tried already and didn't work?
Input and comments are welcome
