Previous in Forum: Power Generation on Steps   Next in Forum: Transformer Impedence
DC Motor Full Load Currents at 125V DC
08/24/2009 9:04 AM
Hi all,
My name is Chris Smith & i work for a small company in Scotland. I have been asked to build a motor starter for a 7.5kW motor on a 125V DC supply, this is something that i have not done before as we usually deal with AC starters.
I am trying to work out the full load current for the motor from standard tables, as the name plate details are unavailable. The only tables I have give the flc for 120V DC, 76A which requires a rather large overload (physical size) for the compartment size.
Finally question - does anyone have a table that shows 125V DC flc for 7.5kW or a formulae that i could use? Any help would be appreciated or a nudge in the right direction. Thanks in advance for anything that you can help with.
Good Answers: 244
Re: DC Motor Full Load Currents at 125V DC
08/24/2009 8:15 PM
Very simple formula for DC motor Full Load current (FLA):
FLA = (KW x 1000) / (Voltage x Efficiency)
In your case, if the efficiency of the motor is 80%
FLA = (7.5 x 1000) / (125 x 0.8) = 75 A
See the link http://www.contractorsunlimited.co.uk/toolbox/electric-motors.shtml
- MS
08/25/2009 4:34 AM
Thank you, it is much appreciated.
Chris.
08/24/2009 8:39 PM
Chris, since kW and kVA equate directly in DC, you only need to determine %efficiency to modify the 60Adc result from your stated values.
What you have asked us is stated in 'nominal' values, and you will need actual measured values to begin with. It would be of great benefit to find the manufacturer details if possible. Missing nameplates are a key indicator of used, and therefore possibly re-wound motors, so a standard table, which is readily available with a simple 'GOOGLE" is at the very least just an estimate. CJM
I do not 'know it all', but i will admit that I would like to. CJM
08/25/2009 4:54 AM
Thanks,
I will see if my client has any more info on this motor.
Once again thanks.
09/02/2009 2:11 PM
Chris, i thought I would add these links to a large number of papers on subjects related to yours, for the benefit of everyone.
The main page has a tab called 'Literature' under which the 'Technical Papers' contain a huge wealth of information related directly and indirectly to many of the common questions about controls, undocumented electric motors, transformers, power factor regulation reality (these guys make and install the real stuff) and generator related control information.
Hope this proves useful to someone, I've polished up quite a few of my own understandings at this site. It does require some searching through the 13 pages of menu, but it's well worth the effort.
Regards, CJM
09/11/2009 4:21 AM
Thanks for the links. I am working my way through the info there.
Anonymous Poster (3); CJMcGill (2); msamad (1)
You might be interested in: DC Motor Drives, Vibratory Tables, Rotary Tables
