Previous in Forum: How to stop texting while driving   Next in Forum: Peak Detection and Hold Query
Nero Burning
08/25/2009 10:51 AM
Dear All,
I am using Nero to write a CD, but when CD burning process is to be completed it shows Burning Process Failed... and CD is not getting burned....
So will u tell me possible reasons and remedies for it?
Re: Nero Burning
08/25/2009 11:40 AM
1) make sure you're using the appropriate media
2) make sure you're not trying to write too much data
Re: Nero Burning
08/27/2009 8:45 AM
I've had the same problem every time I use nero - yet I burn the same files onto the same type CD using other software and it works. Tell you the truth, I trouble shot it a little as nero seems to be the program of choice that most new computers come pre-loaded with, but I gave up as I have alternative software that never fails and wastes my CD-R's. Thus I don't have a fix for your problem, but I will recommend using CD-RW's - so that when nero botches another burn process it doesn't waste any of your $.
Good Answers: 119
Re: Nero Burning
08/27/2009 11:59 AM
Could be hardware or software issue. I had similar problems 2 times.
First one was bad drive. No software would work. Needed new burner drive.
Second time, software was junk. Found a program called "Totally Free Burner " online and drive worked perfectly from that day on. Suggest you try new software first.
Good Luck!
Nigeria - Member -  Member
Re: Nero Burning
08/28/2009 6:29 AM
For me, Nero was dead on arrival.
It couldn't burn my CD when i needed it most. I had similar results on more trials and concluded it had a software defect, especially, when other softwares could burn my CD.
The variuos posts above now shows the problem was not peculier to me and to some extent confirms my conclusion that that particular version of Ner was defective.
cheers,
ethobil
Join us to make the world a better place: Propergate peace.
Hobbies - Musician - Tube Amps Only Please!
Re: Nero Burning
11/03/2009 10:32 AM
Sometimes the quality of the CD can do this. Use another brand and try and clean your LASER.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
bhankiii (1); ethobil (1); HVAC.EST (1); maveric_manic (1); mjb1962853 (1)
