Further to my previous discussion, LINK.
I have had no problem with constructing a peak-detect and hold circuit. I do have a big problem in figuring out how to switch an Op-Amp using a peak voltage that drops its voltage relative to the peak.
An example would help here. I have a NiCd battery that increases in voltage to a peak of say 1.5 volts on the completion of a charge which is demonstrated by a minor voltage drop of say 30mv to 1.47v.
I have an Op-Amp that detects the peak voltage of 1.5 and holds that voltage in a simulation and on breadboard. I intend to use that peak as a reference voltage. Each battery has its own maximum peak voltage charge, so I really cannot set a fixed reference voltage for all batteries. I must use an Op-Amp peak and hold circuit. What I don't have, is a device/circuit that will switch when voltage drops from 1.5v to 1.47v (30mv drop).
I have no problem configuring an Op-Amp that switches either high or low when compared to that of a fixed voltage. Example would be, the "+" pin on an Op-Amp has a fixed reference voltage of 1.5v. The "-" pin has a starting voltage of 1.7v that changes to 1.3v and therefore changes output state of Op-Amp.
In my situation, the "fixed" (peak) voltage is 1.5v on the "+" pin of the Op-Amp (no problem here)...BUT...the "-" pin has a starting voltage the SAME as the "+" pin that then drops to 1.47v that results in no change in output state of this Op-Amp, as there is no crossover from a high to a low state with respect to the peak voltage reference.
Should I be using something else besides an Op-Amp to trigger a switch in my situation?
I have tried many configurations and looked at many ideas, but still am unable to find the "word", component or terminology to describe what to do when there is a voltage drop AFTER the peak and hold. Remember that each battery will have its own individual circuit and will have varied peak voltages.
Any help of any kind would be great. I felt a schematic was not needed, as I don't have one that works outside the typical Op-Amp peak detect circuit.
