Previous in Forum: Clinching the Engineering Cliche!   Next in Forum: How Do You Guys View Vehicle Data?
Hyd. lift cylinder is not being down
08/27/2009 2:58 AM
Dear sir,
Our XCMG 50 ton tyre mounted crane's lift cylinder is not down and all the function like winch,boom extention,swing and also boom up is doing properly. but the boom is not downing.and then we checked the all the hyd line like its counter balance valve of lift cyl. and its spool.how can i solved the problem.
Thanks and Regards
Balaram Sahoo
mobile no-09861363306
Re: Hyd. lift cylinder is not being down
08/27/2009 4:36 AM
Stop asking total strangers to do your job for you and call the, " XCMG 50 ton tyre mounted crane" technician to fix it!
Good Answers: 266
08/27/2009 7:14 AM
Troubleshoot.
08/27/2009 5:53 PM
I agree. Troubleshoot it. Or call someone that can.
After all, do not trust strangers over the internet to do the job for you. We are not there. We will not be able to see everything.
Humm... suspicious you are...
bhrescobar (1); lyn (1); ozzb (1)
You might be interested in: Boom Lifts, Lift Tables, Lifts
