Previous in Forum: rear brakes   Next in Forum: Hyd. lift cylinder is not being down
33 comments
Clinching the Engineering Cliche!
08/26/2009 10:28 PM
Knowledge that voices superiority through rhetoric has already proven to be a human downfall so here's my request for consideration of modern engineeering rhetoric:
Low to the ground cars cause flying downwards by extending the path of air over the vehicle and shortening the path of pressure under the vehicle.
However the current rhetoric states that this is an attempt to maintain a minimal air exposure thereby reducing resistance and creating a zero slip coefficient. And it's not very good sense to flout the current wisdom because it does have significance comparative improvement to previous designs.
But is the rhetoric that ignores downward flying detrimental to vehicle engineering and better innovations? (Along with ignorance of side slip and pressure and sidewards buoyancy which is basically coupled flying towards the center of flight and it's axis).
Or do the better designers know this already but advise the public it's already what they expected; 'Ka ching' sale on zero drag car!
[And besides all this; a rolling grass cutter air fan in front of a rocket car could really put the best face to the front if it could go faster than the vehicle. If designed to glide, cut and bouyancy bounce with faster than fuel computer optimizations but thats overstating my case for possibilities before testing a working design.]
Pathfinder Tags: drag faster than fuel flight
Re: Clinching the engineering cliche!
08/26/2009 10:35 PM
I think you should meet kay williams. You could have some really interesting rousing relevant inane conversations.
08/26/2009 10:51 PM
Always the attacking forward Lyn Lynch -I think that eggs hatched!
Good Answers: 93
08/27/2009 12:05 AM
What?
When I was recovering from a broken hip and hand and pelvis after a bad landing on a concrete slap, I wrote some really strange stuff, that I've yet to delete from my website, simply because it is so strange, as if someone else wrote it that maybe someday somebody else will be able to tell me what it was I was talking about.
In fact I have written things that were totally incomprehensible, even to me.
Anyway so what the hell are you talking about?
Is it a rocket propelled car with a lawnmower on the front that floats on cut grass?
Possibly you ought to take up Painting, as there is a market for surrealistic painting of mechanized monsters.
Personally I think a good car has good ground clearance, and admire the Citroen for its ability to change that according to road conditions.
You don't get wise because you got old, you get old because you were wise.
08/27/2009 12:18 AM
Thanks Transcendian,
I thought maybe it was just me.
Were you in a plane, or free falling, when you had the bad landing?
Good Answers: 93
08/27/2009 1:32 AM
Boss told me to vacuum the walls on the second story of an addition.
I said, "That's a painters job, and really what is supposed to be done is a water wash with rollers."
"The Clients are going to paint, and I want you to vacuum the walls."
-okay, you're the boss, it all pays the same... The clients had also hired an "artist" to put in an ornamental spiral staircase. He was supposed to have shown up to make some sort of platen, and the other guys had taken down the guard rails around the open stairwell to facilitate whatever it was this "artist" needed to do.
-Unfortunately I hadn't noted this detail.
So what happened is that I was walking around looking up vacuuming the walls, and stepped into an open stairwell and fell a story landing on a slab of concrete.
(It is a good thing I had cleaned up the first floor, and moved the compressor, since otherwise I would have landed horizontally on the compressor, and the slab.)
It was also a nice thing that one of the clients was in the house and heard me moaning for I was not going to be able to get up and walk away.
The EMTs were there right quick, and were real sweet. "May we cut your pants off?"
"We need to stick our finger in your asshole."
"Sure you can cut my pants off, but why do you need to stick your finger in my asshole?" -just asking.
"We need to know if you are bleeding internally."
"Oh." thanks for the morphine.
Like they say, a good landing is one you can walk away from.
08/27/2009 2:12 AM
I'm tired of your cliche's today! A good landing is one you didn't fall on!
08/27/2009 3:43 AM
Ouch!...(I hope you sued their ass)
My Brother (not the dead one ) Just had a prostate check up...the Doc said
'That feels normal'
'Not to me' said my Bro', but I expect the Doc has heard it all before.
Good Answers: 93
08/27/2009 7:34 PM
Friend of mine has a similar problem, though I might ought to put it in the new Jokes Thread.
Nurse asked if he had had any sex lately.
"Only with you." he replied.
08/27/2009 7:52 PM
I wonder if that would affect his PSA?
08/27/2009 2:06 AM
Lucky you, you have another attacking forward! (Is this a basketball site?)
08/27/2009 2:07 AM
Long story for your flame thrower fueled by grass!
Good Answers: 58
Re: Clinching the Engineering Cliche!
08/27/2009 10:47 AM
I am travelling, sitting in an airport lounge and very tired. Please could you repeat this in English or tell me what you are taking so that I can get onto the same "planet"?
The words are quite big so I assume this is not a "language" problem.
08/27/2009 9:49 PM
"Your tired" is a horrible way to invalidate someone but "simple comprehension" is a fair request! Hopefully your more bright eyed the next time you see this.
In points;
Engineering perpetuates the same routine assumptions? Agree or not?
An example case; cars are designed to assume optimizations in "zero drag".
But cars can be viewed as a wing forcing the car down (the fulcrum shape)
Which is the real working factor?
But designers know more about the many car movements; do they hide the other design features in "ad slogan rhetoric" or does engineering by convention ignore the aviation knowledge?
Finally; is this example case creating a historical background that will allow a future designers a view of typical human short sightedness.
A historical view normally states; if only you knew the people working on the required technology somewhere else; then your current work would have been inspired!
Good Answers: 38
08/27/2009 12:12 PM
I kinda get the drift about the cars. (pun intended) But maybe we can ask him for his blueprints on his design and get an idea about the lawnmower, rocket thingy?
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
08/27/2009 12:31 PM
He's probably back down off that trip he was on. He won't remember anything.
08/27/2009 9:26 PM
If the last part about using an air cutter left the greatest impression, then anybody stating incomprehension as the total mandate is lying. (plus I reached my target audience of 2%; goodnight lady!)
08/27/2009 6:23 PM
Hi.
Actually, I'm affraid that the concept of inverted wing for increasing the car downforce has been abandoned sometime ago. Mainly, because no one can assure the optimum angle of attack of the car in respect to the observed air stream. As an example, there are several videos in the internet showing car races in the early 80's when cars just lift from the track after some ondulation or vacuum from the car in front of it.
A more modern approach is to use low drag designs as you mentioned to increase efficiency. Racing cars - note formula 1 ones - currently have raised noses to increase body design for aerodynamics. Then, while everything else goes fine, hyperlifting devices - airfoils - movable and/or adjustable, and more prone to control. And, of course, much better eficiency, with engineered profiles that do result in higher downforces with lower drags.
After all, what was the question?
BTW, a flying grass cutter, like a hovercraft or something like this, would be great... just a though that have just arisen...
Regards.
Humm... suspicious you are...
08/27/2009 7:06 PM
"After all, what was the question?". Do you really want to know?
08/27/2009 10:03 PM
The last part you mentioned was the question; the optimizations of downwards forces are a huge key; perhaps the real working theory! I would suppose it's almost an inverted style of aviation and along with other engineering advancements it would be part of dimensional analysis.
Does the rhetoric of zero drag overtake the real working analysis; and possibly detrimentally because it holds back on designs overcoming the air resistance by propelling around it?
(Cutting the air to the other dimensions of the movement plane seems like a more sound theory to me personally, because you can ultimately speed it up and look for "faster than fuel" regenerative moments (what is normally rhetorically recorded as looking for average efficiency!)
Thankyou so much for the fantastic comprehension capabilities shown as a sentient human when answering intuitively amongst a comment melee! :)
Good Answers: 37
08/28/2009 7:03 PM
"BTW, a flying grass cutter, like a hovercraft or something like this, would be great..."
You mean like this: http://en.wikipedia.org/wiki/Flymo ?
" Ignorance and arrogance have more in common than their last four letters. "
08/29/2009 2:48 AM
That's just for an air cushion with coincidental ease in glide not exactly a "forward air cut that pressurizes an accelerated glide cushion whilst maintaining a pathwayway traction capability despite the vehicle size and momentum within a varied system of forces caused by environmental change, desired guidance along pathway and choice of velocity (or feel desired by the occupants)".
Good Answers: 37
08/29/2009 10:04 AM
Please observe that the response was to a portion of post #13, which was quoted for clarity. You seem to be proving that the number 3 and number 10 posts have it right. Is this some esoteric form of binomial theorem test?
I have no idea of what your ending connects with, despite its having been placed within quotation marks. Again, posts #3 and #10 seem to apply. Are you quoting The Voices?
08/30/2009 7:36 AM
"That's just for an air cushion with coincidental ease in glide not exactly a..."
Best read or (now) corrected as; "That Flymo is just for an air cushion."
Sorry if the link to your "The Voices?" came on too strong!
Canada - Member -
09/01/2009 10:27 AM
Is it just me or would an air cushion just push the grass flat to the ground and prevent it from being cut by the blade? And if I'm not mistaken, conventional lawnmowers blade design actually pulls the grass for an even cut....
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
Good Answers: 37
09/01/2009 12:03 PM
Much depends upon how airflow is controlled within the housing; in theory you might be able to pull air up & in near blade tips and force it down & out centrally, but that's tough to imagine. I do know that the Flymo actually worked, so they must have done something right . . .
Canada - Member -
09/01/2009 12:14 PM
I'd still like to see the airflow diagram that would permit this on a mower...unless they spent (and charge) a huge sum of money on this....
Good Answers: 37
09/01/2009 4:29 PM
Well, I haven't seen a good clear airflow diagram, but Husqvarna ("Flymo" is their brand) is still making them after 40+ years, and their website shows sixteen different hovering lawnmower models (http://www.flymo.com/node3126.aspx). One source refers to "fans above the cutting blades" as providing the hover cushion air. The thumbnails for specific models, such as http://www.flymo.com/node2415.aspx?nid=48822, do appear to show a fan above the blades, with air inlets high up on the housing. In the FAQs, there is a reference to tilting the mower in order to start air circulation under the housing, which suggests that there is more to the flow pattern than the thumbnails show (and there are circulation illustrations only for some of the smallest machines in the range). It is possible that they treat the full pattern of airflow as a trade secret . . . They claim to have become the leading lawnmower brand in the UK in 1969, and to have sold a million units there in 2000 [but that likely includes many other products, with the hover mower only a fraction of that volume].
09/02/2009 2:22 AM
Ron
Have had different Flymos over the last 30 years. Useful on banks etc as no "directional" wheels. The old ones did not have grass catchers and worked well. The ones with grass catchers suffer some handling problems as the weight is added. I think it also disturbed the airflow from the lift fan.
The fan is indeed above the blades. The main reason for tilting the mower on start up and stopping is so as not to cut a perfect little circle of very short grass before the mower "takes off" and rises slightly off the ground.
Good Answers: 37
09/02/2009 2:06 PM
Thank you, Guest, for the clarification regarding tilting the unit - much clearer than what I saw in the FAQs. I've never used a Flymo, though I have seen a couple of them in use or being demo'ed. [Actually, I haven't used ANY mower for several years, except to prepare a small area for a garden: I "mow" at my place by moving the sheep into the area that needs it!]
Canada - Member -
09/02/2009 6:41 AM
It makes more sense now that I've seen the pics. Much smaller cutting area than my 22" Craftman but I guess the cut-in-any-direction must make it somewhat faster (than an equivalent width wheeled mower).
Learn something new everyday...... Thanks Ron.
09/01/2009 12:07 PM
True, but the standard mower is a swinging fan, I guess the speed limits the actual forces to not much downward despite the huge gust in the chamber; if anything, all create a venturi effect to aid operation.
08/28/2009 1:46 PM
"Low to the ground cars cause flying downwards by extending the path of air over the vehicle and shortening the path of pressure under the vehicle."
"extending the path of air over the vehicle and shortening the path of [air] under the vehicle." is precisely the traditional explanation for why an airfoil has lift: longer path = higher velocity; higher velocity = lower pressure (Bernoulli/Venturi).
There are lots of other factors, but the shape you seem to be describing should make the car lift, not hold down,
08/29/2009 2:37 AM
Your right if you read my words as a forward convex bubble such as a standard wing but I was considering the raked form of a sports car having two elements
convex nose and concave sweep but like bhrescobar said it's just about optimizing the downward forces,
"And, of course, much better eficiency, with engineered profiles that do result in higher downforces with lower drags."
And the reason I think it works as a reverse wing (not to confused with an upside down wing) is that also less air pressure is available under the vehicle. That makes it the opposite of flying into a lift but I think your bang on with your summary of a flying bubble car being a good airfoil shape.
http://www.maddernracing.com/images/headlines/wing.jpg this is concave raked wing.
Register to Reply 33 comments
Anonymous Poster (1); bhrescobar (1); Brett Johnston (11); charsley99 (1); dkwarner (1); lyn (5); Rick@cae (3); Ron (5); The Prof (1); Transcendian (3); user-deleted-1105 (1)
You might be interested in: Slip Rings, Vehicle Wrapping Services, Vehicle Lifts
