Previous in Forum: First Image of a Single Molecule   Next in Forum: heat resistant epoxy
qty of hot air
08/29/2009 12:09 AM
dear sir
what shall be the qty of hot air required to evaporate 1 kg of water in spray dryer during manufacturing of skimmed milk powder
will it be 35cubic meter per kg of water evaporated
this is open for discussion
spssawhney
09915742601
Re: qty of hot air
08/30/2009 1:02 AM
1 kg water needs 550 kcals to evaporate. 1 cu.m. air can deliver about 0.25 kcal on cooling through 1 deg.C. 35 cu.m. air will have to cool through about 60 deg.C to supply this. Add some more for contact efficiency. If heat damage is an issue the solution may be to use more volume of air. Bioramani
bioramani
Re: qty of hot air
08/30/2009 9:45 PM
You got to specify the air and water temperature. In SI units, you would need a thermal heat input of 2420 KJ to evaporate 1 kg of water (Latent Heat). Considering air has sp heat of 1.015 kJ/kg and assuming you have 60 C temperature drop available for air, then
2420 kJ/kg = mass of air (kg) x 1.015 kJ/kg/C x 60 C, or
Mass of air required to evaporate 1 kg of water = 40 Kg
Air has a specific volume of 22.4/29 = 0.772 Nm3/Kg
So, the volume of air required = 31 Nm3.
Note- this assumes no effciency loss or specific heat input to raise the temperature of water, both of which increase the air quantity required.
Continuous Learning
Re: qty of hot air
09/01/2009 2:57 AM
It depends upon the moisture content of the air being used. Hot or not, if the air is being introduced without a wet-bulb depression, no drying can take place. The greater the wet-bulb depression, the more evaporation takes place for the same volume of air. So, until the air inlet conditions are known, the question is unanswerable.
Register to Reply 3 comments
bioramani (1); PWSlack (1); sv13 (1)
