Previous in Forum: Soldering Tiny Components   Next in Forum: Manufacturing Fasteners
Superficial Tension
12/18/2006 2:54 PM
I have a doubt with a manufacturing process. I am currently submerging a piece into adhesive primer, the problem is I can't assure that the primer is going inside the boss cavity since the piece enters with the boss opening facing down. The boss diameter is about 1.3 mm and has like 3 mm dept. Is there a chance that there could be an air cavity not letting the primer get to the bottom of the boss hole?? This piece is made of polyethelyne, it is freaking difficult to adhere it with adhesive, does anyone have experience using adhesive with this material???
THANK YOU!!
Re: Superficial Tension
12/19/2006 2:35 AM
Yes it is possible that air is trapped in the cavity. I would use a little vacuum followed by pressure to ensure that the air is displaced. ( Much like vacuum - pressure impregnation used in electric motors)
Arjun
Fans of Old Computers - Commodore 64 - New Member
12/19/2006 9:10 AM
Are you submerging the whole piece? If you are then why can't you turn it 90 degrees and leave it at that or have it rotate while submerged. If your not submerging it then could you have a pump and direct the flow at the boss? I am not sure if that would over come the tension, but it is inexpensive.
Reality to one by defintion is illusion to another by defintion. J. Walborn
12/19/2006 4:53 PM
Coating inside high-aspect holes requires control. You could try to inject at the bottom it using a metered syringe. You could then spin the piece or blow into the bottom to cover the sides. The level of control you need will depend on whether/how the primer wets the sample.
