Previous in Forum: 90/10 Cuppro Nickel Piping   Next in Forum: Delay in EDG Starting
Calculating the Weight of a Steel Tank
08/31/2009 9:56 PM
i have a steel tank that measures 6 l.f. high with a circumference of 4.5 l.f..
the steel is .375 in. How do if calculate the weight.
Thanks, tb
Good Answers: 15
Re: weight of steel tank
08/31/2009 10:18 PM
Is this a homework question?
How many college classes have you had?
What do you know about density?
What do you know about volume?
downhill slide to 112 (damn memor.)
08/31/2009 11:11 PM
ddk is right. What are you up to? Send us a picture of the tank and we will help, if it exists.
You said, "i have a steel tank". Is your tank real, or hypothetical?
09/01/2009 6:36 AM
I had one of those hypothetical tanks one ...it was rubbish
09/01/2009 10:39 AM
Hum... calculate the weight of what? Tank itself? Full? (of what?).
Have you already tryied to calculate the material volume and then using the density to calculate the weight?
Sorry but your question is so simple that users here tend to be sarcastic. Give us more details so we can take it seriously.
Humm... suspicious you are...
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Calculating the Weight of a Steel Tank
09/01/2009 4:37 PM
09/01/2009 7:12 PM
To quote, bhrescobar, "calculate the material volume and then using the density to calculate the weight."
This is not homework, I realize. I looked at some of your other posts.
Moose's suggestion is good, too.
Good luck.
Register to Reply 6 comments
bhrescobar (1); ddk (1); lyn (2); Steve Melito (1); user-deleted-1105 (1)
