Previous in Forum: 2002 Chevy Malibu Shuts Off While Running   Next in Forum: Door Closing Efforts?
19 comments
Material for Fuel Tank Rubber Gasket
09/01/2009 3:39 AM
The fuel inlet & outlet carrier plate at the top of the fuel tank has a rubber gasket 3mm thick sealing it. This gasket was supplied as "fuel resistant" but after less than 6 months and 2000kms the petrol has eaten the edge of the gasket and lumps have fallen off lodging in the fuel filter. What material should I use?
Re: Material for fuel tank "rubber" gasket
09/01/2009 3:44 AM
Nitrile rubber (NBR)
Re: Material for Fuel Tank "rubber" Gasket
09/01/2009 8:56 AM
Hi Robbie, it shouldnt be happening if the existing gasket is a good quality NBR ( Acrylonitrile Butadiene Rubber) There are different grades and compounds depending if you are using alcohol based fuel or non alcohol modified fuel.
09/01/2009 9:05 AM
I don't what material was originally supplied, I only know that it wasn't up to the job! Our fuel doesn't have alcohol added, it is 93 octane lead free. A work pal has suggested Viton but I'm not familier with that material.
Re: Material for Fuel Tank Rubber Gasket
09/02/2009 2:13 AM
you can refer to link below
http://www.marcorubber.com/material_chart.htm
cheers..
We shall require a substantially new manner of thinking if humanity is to survive. (Albert Einstein, 1954)
09/02/2009 3:11 AM
Hi
I work for a company making flexible fuel tanks. We use Viton as standard in our fuel tanks and it seems to stand up well over it's life. We receive these tanks back for retest after five years and the Viton shows no sign of degredation.
We have used Nitrile as well and never had a problem with it.
Good Answers: 68
09/02/2009 8:17 AM
Hello Robbie,
Neoprene is resistant to petrol and chemicals and comes in sheets so you can cut any shape you want, OK?
See these few sites below:
  1. Neoprene Sheetwww.GoodyearRubberProducts.com We Ship Neoprene Sheet Worldwide. Call Free 866-711-4673
Search Results
  1. Gasket Material - EPDM, Rubber, Hypalon, Sheet and Roll... surplus neoprene, gum rubber, envelope gaskets and more . Pre-Cut Gaskets · Flange Gaskets · BUY ONLINE! Gasket Material: Sheet, Roll and Cut Pieces ...
    www.allstategasket.com/info_gasket_material.asp - Cached - Similar
  2. Black Neoprene Rolls and Sheet for GasketsGASKET MATERIAL STYLE 1119 - NEOPRENE SHEET (BLACK) SEE SPECIFICATIONS BELOW OR Download PDF Material Specification Sheet - AG-MatSpec-1119.pdf ...
    www.allstategasket.com/info_gasket_material_style-1119.asp - Cached - Similar
  3. Neoprene Gaskets Information | Business.comFind commercial neoprene gaskets and sheet rubber. Several different types of neoprene gaskets fill a wide range of applications. ...
    www.business.com/...goods.../gaskets.../gaskets/neoprene/ - Cached - Similar
  4. Neoprene | Neoprene Washers | Neoprene Gaskets | Neoprene Strip ...Our neoprene washers, neoprene gaskets, neoprene sheet, neoprene pads, neoprene strip, and neoprene seals can all be supplied adhesive backed if required. ...
    www.rhnuttall.co.uk/Materials/.../Neoprene_Rubber.html - Cached - Similar
  5. Neoprene Sheet on ThomasNet.comCompany Profile: Manufacturer & distributor of standard & custom neoprene rubber sheet for sealing & gasket applications. Neoprene sheets have 51 percent ...
    www.thomasnet.com/.../neoprene-sheet-96095880-1.html - Cached - Similar
  6. Neoprene Gasket MaterialNeoprene Gasket Material - Sponge. STYLE R-451 / R431 Black Closed Cell Sponge Black neoprene closed cell (expanded) sponge gasket sheet. ...
    www.gasketing.net/neoprene.htm - Cached - Similar
  7. Gaskets & Seal Materials - Rubber, Teflon, Neoprene, NBR Sheet,Gaskets (GASKETS) & Seals (SEALS) Sealing Materials include plastic sheets, rolls, tubing, rods. Gaskets & Seal Materials including Teflon, PTFE, EPDM, ...
    www.professionalplastics.com/PlasticGasketsSeals - Cached - Similar
  8. Neoprene Gasket Trade Leads - Neoprene Gasket Manufacturers ...Click here to join Image-based Promotion. Image-based Promotion. Sell Neoprene Rubber Sheet · Sell Neoprene Rubber Gasket. Selling Leads ...
    www.busytrade.com/hotkeyword/Neoprene_Gasket.html - Cached - Similar
Hope this is helpful. Let me know please.
Good luck.
10/01/2010 8:05 AM
Neoprene is not fuel resistant. The material you require is nitrile rubber. A hand guide to the properties of gasket materials can be found here. http://www.ramgaskets.co.uk/uploads/Gasket_Material_Properties.pdf
Good Answers: 68
10/01/2010 8:29 AM
Hello RamGas10,
ermmmm, if you own or represent the company you advise others to go to please note; the address as you typed it is not correct. Typed with lower-case letters it works fine, OK?
One other point, the OP (Original Post) was in February 2009, almost 2 years ago, so I would think two things; one: the OP has found what he or she wants from the many suggestions on this thread. And two: your answer is far too late for it to be of any help to the OP.
It may be of help to someone, but other's suggestions throughout the thread are more than adequate to explain what is suitable for this particular requirement.
Good Answers: 42
09/02/2009 9:22 AM
Robbie RSA,
Inert to organic solvent materials could be your best choice. I would like to suggest, NYLON or POLYESTER based gaskets as your choice. You can also test it prior by intense contact conditions and decide yourself.
Nature is so graceful and naked. Human possession is ridiculous.
09/03/2009 12:39 AM
Yeah i would go with nitrile or neoprene. Natural rubber doesn't like some hydrocarbons I think.
Good Answers: 68
09/03/2009 1:21 AM
Hello whezmabeer,
Hope you are well?
Yes this was my original suggestion, and of course, if things get desperate it can be used to patch my 'wet-suite'! ;=)
Take care.
09/03/2009 2:18 AM
Hello baby bear, yes i am well thank, hope you are too. I work in an area where hydrocarbons and animal fats are prevalent. You just cant use natural rubber.
Good Answers: 68
09/03/2009 3:48 AM
Hello whesmabeer,
Yes, I realise natural rubber and hydrocarbons do not mix! Main from my own mistakes rebuilding engines.
Take care.
09/08/2009 6:09 AM
Thanks for all the information and advice. I have sourced some 3mm thick Viton ETP and installed it so I'm sure all will now be OK.
Good Answers: 68
09/08/2009 7:22 AM
Hello Robbie RSA,
Ok my friend, lets hope all is ok.
Take care.
08/25/2025 8:45 AM
VITON, the 1st cousin to Teflon. Impervious to almost anything even at very high temperature range.! Good choice.!
10/25/2018 9:56 AM
I would recommend using Nitrile. Rubber gaskets made from Nitrile made work particularly well with fuels. A personal recommendation would be going for either Buna-N gaskets or NBR gaskets, which I got from a company called Martins Rubber.
Hope this helps!
08/03/2025 9:55 AM
Nitrile rubber sheet or HNBR sheet is the best,
Anuj K. Jain
11/24/2026 12:29 AM
One important consideration is that fuel resistance depends on the specific rubber compound, not just the material name. NBR and FKM (commonly known by the trade name Viton) are both used in fuel-contact applications, but their suitability depends on the fuel composition, temperature, exposure conditions and required sealing performance.
For modern fuel systems, compatibility with ethanol-containing petrol should also be checked rather than assuming that a compound suitable for conventional petrol will perform equally well with every fuel blend.
Neoprene should not automatically be treated as a suitable substitute without checking its compatibility with the actual fuel. I would recommend confirming the vehicle or tank manufacturer's gasket specification and using a certified fuel-compatible replacement. Swelling, cracking, softening and loss of sealing performance are all worth considering when evaluating the material.
irtubes
Register to Reply 19 comments
Anonymous Poster (2); babybear (5); goGreen (1); HiTekRedNek (1); irtubes (1); JohnDG (1); ManufacturingGuru (1); meched (1); RAMGas10 (1); Robbie RSA (2); s.udhayamarthandan (1); whezmabeer (2)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
