Previous in Forum: Statistical Methods   Next in Forum: commissioning of belt conveyors
Hydraulic Cylinder
09/02/2009 11:19 PM
Sir,
I want to do test on hydraulic cylinder, Can anyone help me how i do these following test.
Plz help me.
1. NRV test(As there is one NRV is provided at the end of cylinder where we pressureize the piston to move outward):-In this i want to measure the holding and cracking pressure for NRV.
2.Cylinder friction test:-Measure and note down the static breakway pressure and the dynamic drag pressure under no load conditions.
Plz can anyone help me for these test,HOW I will do this test?IS there is an method to do this test??
With Regards,
Saurabh Maggu
Re: Hydraulic Cylinder
09/03/2009 3:30 AM
Use a hand-operated hydraulic test pump and a calibrated pressure gauge.
09/03/2009 4:51 AM
Thax for giving reply.
But Sir, how i measure the cracking pressure of NRV i think its to b done by some applying load but, i dont know were i used pressure gauge and how i measure the static breakway pressure and dynamic drag pressure under no load condition.
With Regards,
Saurabh Maggu
Good Answers: 266
09/03/2009 7:26 AM
Place a dial indicator on the end of the rod to note rod movement. Use hand pump to apply pressure with calibrate gauge. Note the pressure rod moves.
Register to Reply 3 comments
ozzb (1); PWSlack (1); saurabhmaggu (1)
