The echo amplitude is main criteria for rejecting
defected parts since the first practical use of ultrasonic echo
technique.The DGS (AVG) diagrams announced by J.Krautkramer in were the
first ones that used a disk-shaped reflector as a clear sensitivity and
sizing reference, which was adopted immediately worldwide. Since then:
experimentally measured variations of amplitude with distance from flat bottom holes are known as DAC
the
standard universal attachment scales supplied with different kinds of
Krautkramer high repeatable probes are known as DGS scales.
The
major advantage of DGS scales is that they allow the calibration of
sensitivity and the sizing of defects using one easy detectable
reflector only (inner surface of the cylinder in the very reproducible
reference standard). However, the disadvantage of known DGS is the
relative complexity of the "spider's web" of universal attachment
scale. The "one curve only" shape of experimental DAC makes it a
preferred solution in many cases, in spite of the need to use numerous
reference standards and blocks for each kind of probe, material and
inspection task.
I agree with the previous comments. Both methods are similar. DGS is cheaper as it doesn't involve the manufacturing of calibration test pieces.
Just two points:
If you have to comply with some codes or standards, you should follow the required specific method.
Both methods give a comparison of the echo produced by real flaws against echoes produced by artificial flaws. (In some cases "real-like" defects are induced in the test piece, but this advantage in the determination of flaw size bears an increment in the cost of test pieces manufacturing)
Kind regards
I've read your discussion and I have another question which is related to the topic:
There is a peak in DGS or DAC diaqrams, I mean reasonably we must have just a decreasing diagram when a defect goes in a deeper position,so what is that peak?
The response signal (ultrasonic pressure) decrease with distance for "small reflectors" (smaller than effective beam cross area) inversely proportional to the square of distance but only in the far field region. If you are in the near field region, the response is a different thing, with some maximum and minimum.
kind regards
