Previous in Forum: Transformer vs load   Next in Forum: stamford alternators
relay setting
09/05/2009 3:35 AM
for a 6mw alternator what will be the protection relay setting and related calculation with formula?
Re: relay setting
09/05/2009 5:51 AM
8.26
y=mx+b
Re: relay setting
09/05/2009 11:26 AM
many data are required.
y = mx +b , where y = garbage in , x = garbage out.
6 mw generator, what is the system fault level ?
what type of relay are you using ? - is it a multi function ? or for earth fault ? or for instantenous peak ?
what are the ct ratio details ?
Exploring the Science of Electricity
Good Answers: 244
Re: relay setting
09/05/2009 5:36 PM
The best and more accurate method is to do the device coordination using a software (like ETAP).
-MS
Re: relay setting
09/06/2009 12:10 AM
For a generator that only produces 6mw (that is 6 milliWatts) you should not need any protection whatsoever!
I suspect you meant 6MW. VERY different!
Good Answers: 42
Re: relay setting
09/06/2009 11:42 AM
You pinpoint the lack of clarity!
Anonymous Poster (1); dkwarner (1); GW (1); harry potter (1); msamad (1)
