The present outdoor unit and/or an indoor unit of an air conditioner equipped with a heat exchanger having a plurality of refrigerant passages, and a refrigerant distributor system for use in same.
Why the refrigerant distributor make from brass but not copper? Although the distributor is fitted to the low pressure side (evaporator).
