Hi All
I need a wiring configuration diagram for analouge hour run meter. I now this meter have to be in parallel with the load. The load is a water heater rated at 3kW, 230V.
I also know that these cannot be configer in series with the load (heater). This will just blow the hour run meter due to high load current. Please correct me if I am incorrect.
The hour run meter is Legrand make cat number 004694 (230v 50Hz).
Please help.
