Previous in Forum: Small Generator / Alternator   Next in Forum: Submerged Power Cable
8 comments
VAWT Project Fights Its Way Forward
09/09/2009 9:50 AM
My latest problem has to do with my do-it-yourself stator (need I reprise my last "thread" here?). I have the rotors on the permanent magnet, three phase, alternator built, as do I have the stator. The stator, though, came out too thick - the result of my mold having warped and let the fibreglass resin around the windings come out too thick. With only three thirty-seconds too much thickness, I assayed to sand the stator down.
That exposed some of the AWG fifteen gauge wires. They're not severed, though (the ciruitry is intact, in other words), so I propose to simply paint them over with something and shim each of the rotor plates a millimeter away from the stator in order to keep the rotors from contacting and rubbing the stator.
First, does anybody have an idea about what I should use for "paint?" Second, I've derived a formula by which to estimate how much current I'll lose by the additional separation of rotor plates and stator. My math is about as good as my electrical engineering, however, and the 16-19 percent decrease might not be so good.
Or should I just built (groan) another stator plate - and get it right this time?
Good Answers: 101
Re: My VAWT project fights its way forward . . .
09/09/2009 12:30 PM
I vote to do it right, and not cut corners. Thats just me
09/09/2009 2:01 PM
RVZ717,
Thanks for the response. And, yeah, me too. I've built three stators, however - this one is the third - and just can't seem to get the product I want. Each mistake costs my pocket book, too.
Of course, I'm learning, and the next stator mold will take into account everything I've learned. In case anybody else is doing something like this, or might be intending it, I also screwed up when I poured the resin around the magnets on my rotor plates, that when I poured too much and covered them. The rotors wound up being too thick, the result that I'm having to laboriously grind them down to size.
Ah, well. Like I said, I'm learning. If I put this damned thing together and the rotor plates touch the stator, I'm screwed: I'd probably have to build a wheel-puller to get them apart and that would no doubt damage the magnets. Then, too, if the stator fails after I put the rest of the together, charge controller and the rest, and get thing up on the roof, I'm also screwed.
I think I'm about to design another stator. Thanks again for the input.
09/09/2009 5:11 PM
Glyptal red insulating enamel. It is available in spray cans for easy application.
See here: http://www.glyptal.com/1201tech001.pdf
It's made for what you are trying to do. Nearly any electrical supply house will have it or a reasonable facsimile. It should be available anywhere in the world.
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
09/09/2009 7:57 PM
THANKS! Great idea!
Re: My VAWT Project Fights its Way Forward...
09/09/2009 3:50 PM
'Paint' it with epoxy resin, then blast it with a hot air gun that will help it flow and cure quick too.
Ok, you've made a few mistakes..but press on...that's how we all learn.
Get it finished, then worry about the mkII.
Good luck
09/09/2009 8:03 PM
Thanks for the response. I'm concerned about thickness, and I've already tried using the resin I made the stator from. That added too much to the stator dimensions, and I had to sand it off. I didn't try the air gun, though, and I'll remember that for my next attempt at a stator.
And yes, I'm learning from my mistakes - just "pissed" that I didn't think of them before I made them. I ought to be smarter than that at my age.
Thanks, again.
Good Answers: 62
Re: VAWT Project Fights Its Way Forward
09/09/2009 10:32 PM
Sure wish I could get to my old links...
There are a bunch on the web up some canyon in Colorado I ran into because they were restoring an old steam engine and making their own generators.
Great tall old engine whose name I cannot recall
I gotta get some off-board storage for my brain
09/10/2009 3:05 AM
Register to Reply 8 comments
edignan (1); Randall (1); RVZ717 (1); Turbotroll3 (1); user-deleted-1105 (1); Walks-in-Storms (3)
