I am building a small sample or demonstration circuit of a battery charging circuit commonly found in engine driven applications. Ideally, I will have an AC motor belt driving a small generator that is controlled by an external regulator.
I am looking for suggestions for small generators (approx 6"x6"x6"). Budget is the first constraint as I am trying to stay under the $100 US range. Height is the more critical dimension as I am trying to make this low profile when being belt driven by a motor. I can use an alternator if required, but I would prefer to make use of an external regulator.
Any suggestions on where I can find a small generator?
