Previous in Forum: No Voltage from Phase A to Phase C   Next in Forum: What to do After Graduation?
How to Mount a Temperature Sensor in the Aluminum Tray
12/20/2006 10:28 AM
Here i want to know how to mount the temperature sensor on the aluminum tray itself, that sensor won't sense the tray temperature,its should sense the tray top side PVC liquid bags..but the tray itself we have to give some holes aare somthing like that..or what is the procedure to mount like that...or any other method is there to mount...that sensor may be a NTC-sensor or thermocouples
Nagarajan.P
India-Chennai
Want to know more in this world...
Good Answers: 54
Re: How to Mount a Temperature Sensor in the Aluminum Tray
12/20/2006 8:19 PM
Nagarajan,
A little more detail please. You seem to be assuming that we know what you're talking about. Please describe your situation and equipment more thoroughly.
12/20/2006 11:07 PM
Can you supply more details or may be schematic of the tray .
12/29/2006 8:31 PM
Silver loaded epoxy resin, should be able to fix a thermocouple/whatever to the underside of an aluminium tray. There is probably no need to drill holes. Insulate the bottom of the tray, if this is practical. then the sensor will read the top surface temperature accurately as aluminium is an excellent heat conductor.
i.e. 2.37 W /cm/C.
"Neither man nor woman can be worth anything until they have discovered that they are fools. The sooner the discovery is made the better, as there is more time and power for taking advantage of it." William Lamb
Register to Reply 3 comments
Alastair Carnegie (1); Anonymous Poster (1); Vulcan (1)
