Walkman is Sony's portable audio cassette player brand, now used to
market its portable audio and video players. A lot of people choose
walkman as their MP3 player to kill time when they are free. walkman
provides its user an important function is to play videos. Some people
know how to put dvds and videos on it, some not. In the following text,
I will show everyone who has a walkman and want to enjoy videos on
their players.
Before reading the guide, I need walkman users to know a few general parameters.
Sony Walkman supports viewing JPEG photos and supports playback of MP3,
WMA, DRM protected WMA and unprotected AAC audio files. Sony Walkman
also supports high quality video playback at 30 frames per second, the
supportable video codec MPEG4 and AVC baseline H264 in .MP4 extension.
Now I will explain how to put dvds and videos on walkman.
I divide this article into two parts:
1. How to put dvd on walkman
2. How to put video on walkman
To complete this process, I need a tool called 4Videosoft DVD to Walkman Suite
Part 1: How to put dvd on walkman with DVD to Walkman Converter
Step 0: Download and install 4Videosoft DVD to Walkman Converter
Step 1: Import DVD.
Place the DVD into your DVD drive and click the "Load DVD" button to load DVD.
Step 2: Video settings.
Select the output video format you want from the "Profile" drop-down list.
Step 3: Place video
Click "Open Folder" button to open your output destination file.
Step 4: Start conversion
Click the "Start" button to start your conversion and in a short while it will be finished.
Part 2: How to put video on walkman with Walkman Video Converter
Step 0: Download and install 4Videosoft Walkman Video Converter
When you finished the download process, run the .exe file to install it.
Step 1: Click "Add files" button to import videos.
Step 2: Extend the "Profile" category to select an output format.
Step 3: Click "Open Folder" button to open your output destination file.
Step 4: Click the "Start" to convert.
Tips----- Basic functions for all the 4videosoft:
1. How to change your video effect
If you want to adjust the effect of your movie, please click the
"Effect" button and a pop-up effect window will appear. It allows you
to edit your movie's effect including "Brightness, Contrast, Saturation
and Volume".
2: How to crop off the black edges and adjust the size of video play region
By using the "Crop" function you can crop off the black edge of your
video and you can also drag the line around the video image to adjust
the video play region to fit for your mobile devices
3: How to split your video
The "Trim" function also servers as a video splitter for you to get any
time-length video episode. You can set the "Start Time" and "End Time"
to set the exact time-length of the clip or you can directly drag the
slide bar to the position you want.
4: How to join the videos
If you would like to put several files into one output file, please tick the check box of the "Merge into one file".
5: How to save your favorite picture
If you like the current image when preview video, you can use the
"Snapshot" option. Just click the "Snapshot" button, the image will be
saved and you can click the "Open" button next to "Snapshot" button to
open your picture.
