Previous in Forum: Measuring Current from an AA Cell   Next in Forum: Medium Voltage Transformers.
Reliability of SMD Components vs. THT Components
09/10/2009 2:05 AM
Hi all
we are in the process of the changing our design of the higher end power sullpy. in the process we changing resistor, capacitors and diodes to SMD components from the presnetly through hole components. is there any concerned on the Reliability of the SMD components compare to the through hole components.
Re: Reliability concerned on the SMD components compare to through hole components
09/10/2009 2:47 AM
You are changing to SMD...
Why?
Unless there is a good reason, I wouldn't do it. The reason may be cost, time, size etc.
We I recently re-layed one of our boards as surface mount....it never made it into production.
The numbers just didn't add up unless the batch size became huge.
You also lose a lot of flexibility and repairability.
Maybe I'm a bit of a Ludite...
I am also suspicious of reliability since the change to lead free solder (I prefer the stuff that actually melts)
Good Answers: 73
09/10/2009 8:52 AM
I wonder if the new solder won't create more defective products thereby increasing the flow of waste materials into the landfills
Good Answers: 119
Re: Reliability of SMD Components vs. THT Components
09/10/2009 5:17 PM
We started change to SMT over 15 years ago. For a short time we had minor issues as we adjusted to the new parts. Certain "tweaks" were required on the design of PCB solder pads and in our solder process. End results were well worth the effort for our products. PC boards were much smaller with significant board and parts cost savings. All our SMT converted and new circuit designs performed better and were more reliable.
mjb1962853 (1); NotUrOrdinaryJoe (1); user-deleted-1105 (1)
